brake/reverse light dont work
From the moment I bought this car the brake/reverse lights did not work. All I have done is check the bulbs to see if they are good, and they are. From anybody's experience where would I start to see where the problem is?? any ideas??
What year is your car? Depending on the year, the brake lights are triggered by two pressure sensors on the master cylinder. Not too sure about the reverse lights. Did you check the fuses?
kb mercedes GLK350 2009 boxster s 86 targa |
Fuses, backup switch on trans and brake light pressure switches. After that get a simple continuity test light and a partner and track down where you loose your electric charge.
Dan in Pasadena '76 911S Sahara Beige/Cork |
my car is a 1982 porsche 911 sc
Had a similar problem with my 80 SC
Could be the backup light switch located on transmission > gain access via the transmission access hatch on rear floorboard... It's a tight fit.. I think the part/switch was $45 or so...
Kim Langley 2012 Carrera / 991.1 80 911SC 97 C230 73 BMW 2002Tii |
