78P930's Avatar
Where can I find tool for door striker plate.
Looked in Pelican but couldn't find it.
Thanks,
Pat
10 Ford Raptor
86 930
Old 04-09-2007, 03:56 PM
I bought mine at the local Pep Boys. It was a set of 4 I believe with different sizes.
Old 04-09-2007, 04:05 PM
DP935 member
kycarguy 935's Avatar
Snap-On sells one too but its expensive.
Porsche Slantnose M505 M506 group on Facebook.
https://www.facebook.com/groups/719995181372494/
Old 04-09-2007, 04:56 PM
Registered abUser
TerryH's Avatar
A T-40 torx socket seemed to fit pretty well. Probably not the perfect tool though.
'81 911SC Coupe SOLD
Old 04-09-2007, 05:15 PM
Bland
unclebilly's Avatar
Sears?
Old 04-09-2007, 05:17 PM
pwd72s's Avatar
What you want is an 8mm "triple square" 3/8" drive socket. Call your area tool sellers, you're bound to find one.
Old 04-09-2007, 05:24 PM
}{arlequin's Avatar
google "zdmak" or hit here: http://www.toolss.com/wbstore/main.asp?action=PROD&PROD=JT-XZN1008PC&CTMP=1
if you type in "triple square" in the search box, you'll get more choices.... don't use torx. paul is right, this is the correct tool.
dave
1973,5
Old 04-09-2007, 05:31 PM
I got mine at the local Shucks. Set of 4 for like $10-15 or something.
Rob
1980 SC - 2011 Tiguan - 2018 Tesla M3P
Old 04-09-2007, 05:50 PM
Zeke's Avatar
I don't remember whether it's a 10 or 12 mm, but Pelican does have them.
http://www.pelicanparts.com/catalog/ShopCart/TOOL/POR_TOOL_CAT066_pg6.htm#29
Old 04-09-2007, 06:02 PM
78P930's Avatar
Thanks all.
Pat
10 Ford Raptor
86 930
Old 04-09-2007, 07:40 PM
pwd72s's Avatar
Unless they went to different striker plate bolts in later years, it's 8, Milt. I just got back from the garage after double checking with my 3/8" drive 8mm triple square socket...
Old 04-09-2007, 07:48 PM
Zeke's Avatar
Yikes! Way off. Well, I didn't see an 8 in the catalog, so I was clearly guessing on that one. The thing is, I have all 3 sizes, so I didn't think on it too much.
Old 04-09-2007, 08:28 PM
Jeff Hail's Avatar
Its part of the metric adjustable spanner collection
Jeff Hail
"All men dream: but not equally. Those who dream by night in the dusty recesses of their minds, wake in the day to find that it is vanity; but the dreamers of the day are dangerous men, for they act their dream with open eyes, to make it possible"
Old 04-09-2007, 09:02 PM
Probably not the *proper* tool but I managed to adjust mine with the right sized allen wrench out of a metric allen head set. Just made sure that the socket was cleaned out and that the wrench was well set into the socket. The important thing was that it was out of a metric set for a tight fit; none of the SAE ones will fit tightly.
'83 SC Coupe
Old 04-10-2007, 02:29 AM
Kirk911SC's Avatar
Any advice on how to remove a stripped striker bolt?
I guess I have to use one of those drill type bolt removers?
Thanks.
Kirk
- '00 Dodge Viper GTS - Steel Grey - Yep...a domestic.
- '87 930 - Guards Red - Sold
- '82 911SC - Grand Prix White - Gone
- '78 928 - Silver - Long gone
- '04 Subaru WRX wagon - Sold
Old 04-10-2007, 05:02 AM
Slumlord
Porsche_monkey's Avatar
You should be able to tack weld a piece of square stock and use an adjustable wrench. Or just drill the head out with a large center drill. PM me if you need to borrow any tools.
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 04-10-2007, 05:07 AM
pwd72s's Avatar
The set I have is the one Dave linked to. Kirk..your bolt probably got stripped by somebody using a hex or a torque socket when trying to remove or install. Clicking on Milt's link did lead me to an 8mm triple square offered by our host...
Just joshing you a bit, Milt...I probably did what you did. Took the set to the car, tried one, then another, until I got the fit.
Old 04-10-2007, 08:39 AM
78P930's Avatar
Done and done. Nothing like having the right tool, found them at the local auto parts store. Thanks again, Pat
10 Ford Raptor
86 930
Old 04-10-2007, 05:14 PM
