hmd hmd is offline
S, M and A calipers
I know the S are alumium calipers.
What is the different between the M and A calipers and how do you identify them.
TIA.
76 Carrera 3.0 (Group Sc)
Old 04-13-2007, 05:32 AM
Bill Verburg's Avatar
A & M are both multipiece iron calipers
A - 3.5" mounts 2x48mm pistons
There are several versions of the M
all have 3" mounts and are multipiece iron calipers
front M's have 2x48mm pistons, rear M's have 2x38mm pistons
and there are wide A & M from '84-89 Carrera
These are A & M
Bill Verburg
Old 04-13-2007, 06:16 AM
djpateman's Avatar
Some of the M calipers also have the 42mm pistons. These were used on the 914 front (no spacer for non-vented rotors), and the '84-89 Carrera rear in wide form (14mm spacer for 24mm rotors).
The 914 calipers have the inlet pipe in a different location and were used up to 1972. Later 914 fronts were similar, but slightly wider for thicker pads and were different castings. AFAIK all M calipers use the same pads with the noted exception of the late 914 with the thicker (but same face size) pads.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 04-13-2007, 07:59 AM
As I know next to nothing about 914s I'll take your word on that.
There were M front, again w/ w/ 2x48mm pistons used on the earliest 911s w/ 18mm solid rotors rather than the vented 20mm used on S and all other 911 '72-'83
The part #s for the 914 front calipers are
914/6 (I always thought that these were the same M used on 911 w/ 18mm solid rotors)
911.351.907.00 /L
911.351.908.00 /R
914/4 -'72( I always thought that these were L's but am not at all sure)
311.615.107B /L
311.615.108B /R
914/4 '72 -(as above)
914.351.425.00 /L
914.351.426.00 /R
and there is a difference between the 914/4 and 914/6 rotor but again I haven't a clue as to what the difference is. There were several different versions of the M fronts used between '64 and '72 but all 911/912 used 2x48
Bill Verburg
Old 04-13-2007, 09:32 AM
djpateman's Avatar
914/6 front calipers are the basic M 2x48mm pistons, spaced for the 20mm vented 911 rotor. Vented front rotors, unique solid rear rotors. The 914/6 GT had even more unique vented rear rotors.
914/4 front rotors are a VW 411 part.
The early 914/4 front calipers look identical to the 911 rear calipers in both 2x38 & 2x42 versions except for the lack of spacers to widen them for the vented rotors, and the fact that the line inlet goes in the back behind the piston.
Addicted since 1975
Old 04-13-2007, 06:08 PM
