I am having cold start and now hot start "issues" with the CIS in my 1978 RoW SC.
In reasearching the problem a Bosch book references a special tool. There is a mixture adjustment screw that is buried in the fuel distribution unit. They said that you need a special screw driver to get at it ( seems silly to me, maybe they don't want the average Joe reaching in there and messing with using a pocket knife). I would like to purchase this tool or or maybe somebody has an easy trick for making your own out of an old screwdriver. Thanks! Andrew
(6) cars currently in my garage:1976 Porsche 912E #627 Ascot Green 1986 Ferrari Mondial 3.2 Coupe Brown/Tan 1986 Porsche 911 Carrera 3.2 Paint to Sample Brown/Brown 1985 RoW Mercedes 420SEC C126 Coupe Brown/Tan, 1978 Alfetta GTV with a TwinSpark, 1997 BMW Z3 1.9 Boston Green/Beige 5speed |
Somewhere in the Midwest
just use the 3mm L-shaped allen wrench out of your Craftsman set...or get one. The "L" should be about 5 inches long or so to get to the screw.
Senior Member
Yes, a 3mm Allen tool works fine, but it has to be just about EXACTLY the correct length to turn the corner and get in the hole.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Once again Pelicanites come thru! Thanks guys!
HI the tool you require is P377 which is 104mm long 3mm allen key and 'T' top of 4mm round bar 40mm long welded on the top.
regards mike |
This is the special CIS tool
Souk's suggestion works just as well.
Found it! Thanks Adam!
HI a Tip for you when adjusting the CO% with the tool, do NOT leave it in between adjustment as the weight will change the CO%, and also, always adjust from weak to rich as the adjustment relay arm with the adjusting screw in sticks and will drop when you don't want it to, then the engine will run on a weak setting. Adjust the CO% from weak to rich and rev' the engine between each adjustment to settle the sensor plate arm, make the adjustment as quickly as pos' as not to let the intake manifold get to hot and alter the CO% setting with heat transfer to the injectors.
regards mike |
Andrew
19 years and 17k posts...
Mike,
Thanks for the tip about not leaving the tool in place between adjustments. Maybe that's why I had trouble setting the mixture correctly...
Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com |
Personally, I wouldn't go tweaking the mixture adjustment without knowing my system, cold and hot pressures relating to starting and driveability issues. Buy a CIS gauge first before setting forth with the allen wrench. I don't understand why guys are so quick to fool with the mixture. Become a Porsche physician: "Do no harm."
Brian |
HI ruf-Porsche to add to your list of tools needed, is a Fuel Pressure Gauge P378 with adapters, to check the system and control pressures, before you do any CO% adjustment, cold and hot. Do not forget the info book "troubleshooting guide K-jetronic" part No 4533.20
regards mike |
Keeping things stoichiometric, Brian |
Mike
Good tips --- but also remember NEVER blip the gas with wrench in place. You could bend the plate
----------------------------- Ernie 81 SC |
I just received the tool from Pelican. Is there a reason why mine is 6 inches long? Do I need to cut it? it doesnt fit.
Listen to the guys who tell you not to adjust it until you figure out what is going on. My cold start issues in the past have centered around a bad warm up regulator. Somethime cold and hot start issues are the cause of a bad fuel accumulator. I personally would not start adjusting the fuel mixture until you check out the system pressures, make sure the filter is clear and the warm up regulator and fuel accumulator are good.
i get the 5" or 6" long 3mm allen socket replacement bits from the tool truck, heat red where i want the length and bend 90° for the handle.
a new WUR curred my starting issues as above.
I just thought it was weird that I bought a factory tool from Pelican and it was too long. I had to cut an inch off of it to fit.
Certified Southern Dumbass! 83 911SC with 993 conversion, 98 Ford Expedition 4WD lifted beast, 98 Jeep Grand Cherokee, 01 Ford Taurus, 99 Nitro Bass boat, and a riding lawn mower
