Anyone Have any Good Solutions on Cleaning up Wiring Harnesses?
I'm putting my 72 911 2.4 T back together.
I want to clean all of the different wiring harnesses. I was thinking about getting some shrink wrap tubing to clean it all up. The problem with that is that several wires need to escape from the harness midway. Any good solutions for cleaning this up? Anyone have any pics of 2.4 engines with their solution? Thanks. Ian |
Air Medal or two
Do not know tha exscape deal...but paint thiner makes all things new and shiny for me anyway. Pain in the bunn job,just part of the program i guess.
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between. |
Bird. It's the word...
I used split tube which is exactly designed to do what you want. You can get it in most colours and it's cheap...
John Forcier Current: 68L 2.0 Hotrod - build underway |
I personaly like wrapping up the wiring harnesses tight with a couple winds of good electrical tape. A good flexible tape will allow you wrap around the wires that need to 'poke out' and the finished outcome looks OEM.
Charlie Stylianos 1982 SC Targa www.Dorkiphus.com - (The Land of the NoVA/DC/MD Porschephiles) |
I used some gunout orange engine cleaning on a rag, then the electrical cleaner that sprays on and dries quickly. After that I wrapped the harness in black tape and used the split tube that Fishcop is speaking of...looks good now!
John |
I, to have done long sections of wire harness with black electrical tape. It's easy to work around wires branching off and gives that "old school" look.......
Bob S. 73.5 911T 1969 911T Coo' pay (one owner) 1960 Mercedes 190SL 1962 XKE Roadster (sold) - 13 motorcycles |
Bandwidth AbUser
Split tube? Where is it available? Thanks!
Jim R. |
Super Moderator
just about any automotive supply store Jim. It's corrugated tube with a split downt he side. Comes in different diameters and lengths.
Bandwidth AbUser
Thanks Chris. Are you talking about the plastic stuff I frequently see in auto parts stores? For some reason I was thinking about something made of rubber, similar to what's put in by the factory.
Jim R. |
I use the longer lasting and tougher Scotch/3M Super 33+ Pro Grade vinyl elec tape.
Split loom is available at any speed shop.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Split Loom wrapped with vinyl.
PMB Performance
I like cloth tape... Older School
Eric Shea - PMB Performance 855-STOP-101 We Restore Vintage Calipers www.pmbperformance.com |
Electrical tape is great until you need to access the wiring harness later to track down a short or something. You'll curse the day you had that idea, trust me I've been there!
Michael Sans Porsche...for now 2009 Mazdaspeed 3 Grand Touring daily driver / DS autocross toy 2010 Subaru Forester X Limited - wife's daily driver |
the split loom covered with tape is easily accessed with a razor blade. Wham bang and it's cut and opened up. Bare wires wrapped in tape is a pia.
Lokk here for braided and woven split tubing
I can get the split plastic loom cheap at the local hardware store, OSH. Very common stuff, just look in the electrical dept.
They won't have it in teal though, just basic black
Chuck Moreland - elephantracing.com - vonnen.com |
Eastwood has a tape that is very much like the material that is used in auto factories for bundling wires. It is like black electrical tape but without the sticky back.
Jerry JM PRODUCT DESIGN |
Here is an example of the best way to make a wiring
harness using hear-shrink tubing. Heat-shrink is inexpensive and easy to use The wire being broken out has some heat-shrink that goes back into the main harness some distance. It provides strain relief where the wire exits the harness. It can be a single wire as shown on a branch in the harness containing many wires. As the main harness continues, note the overlap of the tubing at the break-out. You would assemble this from right-to-left, shrinking the tubing as you go. This is time consuming but produces a professional appearing harness. There is a lot of test fitting involved to do a one-off. Anytime you want to build more than one harness, a plywood fixture is worthwhile. Best, Grady |
Another problem with regular electrical tape is heat and if you ever need to remove it. It makes a big, sticky mess.
