Speedo Needle Removal ?
I have a 71 and need to remove the Needle on my Speedometor to fix my odometor, it is miscalibrated. How does the Needle come off, I tried pulling on it but it didnt budge and I dont want to break it.
71 Targa 2.4 WEBERS 915 box Drivetrain - http://forums.pelicanparts.com/porsche-911-technical-forum/410787-drivetrain-project-complete-3yrs-pics.html Interior - http://forums.pelicanparts.com/porsche-911-technical-forum/452686-interior-refurb-carbon-fiber-71-a.html#post4433500 |
I would suggest Powls Sspeedometer in Lancaster Pa or Palo Alto Spedo in Ca., Not sure it is diy stuff,although i cant blame you for trying.I am having powls do a MotoMeter for a BMW twin i own $150 full rework/synch.
HB Kramer (4 sneaks and 6 airheads): 79 911SC Coupe (sunroof delete) (2 sneaks and 2 airheads): BMWS: R12GS(a) R90S, and some old British iron as well. |
thanks for the info, but I have fixed speedo's before w/ no problem. Im just having a prob w/ getting the Needle off the Shaft its on. I feel pretty good about fixing it once I can get it off. Anyone been here before?
71 Targa 2.4 WEBERS 915 box Drivetrain - http://forums.pelicanparts.com/showthread.php?t=410787 Interior - http://forums.pelicanparts.com/showthread.php?p=4433500#post4433500 |
Can i send you mine??
I have seen some that thread on ,that might be the issue,call Powls ,ask for Kai he'll know.
Work in Progress
If I remember correctly you have to mark exactly where the speedo needle lays. Then you can twist it too far one way then too far the other way until it is loose enough to pull off. That is what I did with a tach recently and what I read when I did a search, but I haven't put the tach back together yet.
"The reason most people give up is because they look at how far they have to go, not how far they have come." -Bruce Anderson via FB -Marine Blue '87 930 |
Sounds Easy enough except for Marking the exact spot to reinstall.. anyone can confirm this? Thanks Rich!
Ok, Ive tried Pulling/Prying and Twisting the Needle off, Its not budging.. I dont want to scratch the Face either... Any other suggestions.. this is in a 71 car..
Sultan of Sawzall
Mitch, I have a speedo/tach needle puller tool you can borrow if you wish. Did the trick on my '86's when I did repair and changed gauge faces, and I've had a few other folks use it as well. Where y'at? I'm up north in SHV/Bossier, but I guess I could mail it to you.
Gruppe B #319 2 '86 911 Carrera coupes (red & white) '66 Corsa convertible 140/4(red) '66 Monza coupe 110/PG(white) '95 993 cabriolet (wife's) |
Thanks Roux, I was able to use 2 Small screwdrivers from opposite sides of the Collar on the needle and pry it off.
Heres my new issue. The reason for dissassmbly is bc my Odometor/ Tripometor didnt work. I now know why. The Shaft going through the Odometor Numbers should be Flanged on One End (the RIGHT side of the numbers) allowing it to "grab" the Metal Grey "gear" (location - touching the First number on the right). thus turning both the Trip and Odo. Since mine doesnt have this flange anymore the Shaft just spins Freely inside the #'s as the Speedometor cable drives it. Anyone have any ideas as to how I can "Flange/Enlarge" the end of the Shaft going throught the #'s , to have it Seat to the metal Grey Gear?
Brian |
