Upgrading to Power Seats
I am going to upgrade the seats in my 83 sc to power; could someone suggest the gauge of wire to run from the battery to the seat to power them?
Also, I would like to put a "in line" fuse, any suggestions as to the size fuse? The seats are out of a 86 and it looks like they have warmers in them
Brad 1983 911 Cabriolet (daily driver) 2000 ML 320 (Shared by teenagers) 2005 Pilot (Wife's) |
I installed pwr seats with overkill 12ga wire. I use 10amp circuit breakers on each. Without looking at the seat motor specs 14ga and 5amp CB may sufice. General text should state to operate the motor at 70% of breaker amps. Marine supply has nice CBs.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
What is the difference in weight between the seats? Might be easy to find a customer for the manual adjusment seats.
diverdan |
no hard info but the pwr seats is noticably heavy and with the heater it's very noticably heavy.
cycling has-been
a non-power sport seat from 84-89 is ~ 37 lbs.
a powered (4-way) RS-A seat from a 93 is ~ 47 lbs I used 12 gauge w/o any additional fuses, as I drew power from a terminal on the fused side of the main fuse block. Bill K
73 911T MFI, 76 912E, 77 Turbo Carrera Last edited by bkreigsr; 04-16-2007 at 05:47 AM.. |
Thanks for the info; I already have the seats
when you refer to Marine Supply is the a general reference to a marine supply store or the actual name of the store--I know, silly quesiton
general reference marine electrics have to meet higher standards than auto electrics. many good stores but a popular one is www.westmarine.com
I used 12ga. wire as well.
