shbop's Avatar
SC carb conversion--which ignition?
For those who have switched their 80+ sc's to carbs; what did you do to your distributor?
1. nothing, left it alone, and it ran fine
2. sent it out for modification
3. just swapped it out for a 78' or 79' distributor
4. bailed on the distributor and went with different ignition.
5. since the case was apart, changed the drive-gear and used a 004.
Not going to split the case, at this time, so the 004 is out.
I'm curious, as the opportunity costs are significant. Quotes for distributor re-curving range from $200--$600 + shipping + two-four weeks turn-around time. I thought about the MSD route, but it only offers 20' advance.
Jon
Old 04-13-2007, 11:54 AM
Work in Progress
Rich76_911s's Avatar
The 80 SC I bought had electromtive crank fire ignition on it. Sometimes you can pick up Tec-1 units and sensors etc relatively cheap on ebay.
"The reason most people give up is because they look at how far they have to go, not how far they have come." -Bruce Anderson via FB
-Marine Blue '87 930
Old 04-13-2007, 12:01 PM
rfuerst911sc's Avatar
83SC- I kept the stock CDI and had the distributor recurved. A good recurve/rebuild will cost $400.00-$500.00.
Old 04-13-2007, 01:48 PM
shbop's Avatar
Thanks for the replies. Has anyone tried dropping-in a 78-79 distributor, with no mods?
Jon
Old 04-13-2007, 03:38 PM
Re: SC carb conversion--which ignition?
5. since the case was apart, changed the drive-gear and used a 007.
Not going to split the case, at this time, so the 007 is out.
Jon:
Several options for you:
1) Leave it alone without the vacuum advance. It will run OK but not as snappy in the mid-range as would be possible. Gasolines play a big role here.
2) Have your dizzy recurved to match. This offers the best overall performance since the stock advance curve in an SC is "lazy".
I would strongly recommend using an MSD 6AL for all carbureted 911's.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 04-13-2007, 04:40 PM
