-   -   when import jacks go wrong- CAUTION- scary pics. (http://forums.pelicanparts.com/porsche-911-technical-forum/341149-when-import-jacks-go-wrong-caution-scary-pics.html)
haycait911 04-13-2007 10:06 PM
was jacking up the rh side of my '73 yesterday when a pin on my floor jack broke. quarter panel hit the jack. NEVER NEVER NEVER have ANY part of your body under a car while jacking. and when putting in jackstands, make sure they are the first thing under the car as you slide them in. fortunately I know a bodyman ( LOL-me) so the damage is well on it's way to being fixed. PLEASE be careful when jacking, 911's are light cars but they'll still squish you dead. Don.http://forums.pelicanparts.com/uploa...1176526988.jpg
Don Plumley 04-13-2007 10:08 PM
Ouch. Glad you are okay.
k9handler 04-14-2007 01:56 AM
was thinking this yesterday when placing jack stands under my big arss van! My son was helping me and could not understand why I was pushing the jack stands under with a stick.
Zef 04-14-2007 04:10 AM
Thanks for advice Don...
oly 04-14-2007 04:17 AM
haycait911,
Thanks for the thread! What manufacturer and jack model did this?
Porsche_monkey 04-14-2007 05:15 AM
God's way of telling you your car is too clean. Stop working on it and drive it. :)
Please post a picture of the jack and the broken pin.
unclebilly 04-14-2007 05:54 AM
ON this note, when you reach under the car to put your jack stands in place (or what ever else you reach under for) always lay on your side and reach under the car with your lower arm. If the car does fall, likely nothing will happen to your arm - worst case it will be pinched.
If you use your upper arm and the car falls, you'll probably dislocate your shoulder, break your elbow, possibly both your radius and ulna etc... Just because your car will make contact with your upper arm before anything else on it's way down.
It's a simple thing to keep in mind JUST IN CASE.
Porsche_monkey 04-14-2007 06:12 AM
Just a guess. Mastercrap stands?
I have some reasonably good 'large-ish' stands, which after further inspection don't look all that good. I will either re-weld them or bolt the braces, the welds look like crap. I have seen some stands that are cast or stamped, not welded, I think they would be safer. The problem I have found is that the good stands are way too high, too heavy, and too awkward. But the 'nice size' stands are sub-standard imported crap.
It's nice to be able to buy a spatula for $0.49, and a winter coat for $29.00, but I don't rely on a spatula to protect my life. Sometimes you want to pay more for better quality, but thanks to Wal-mart and the race to the bottom, there is only crap for sale.
I would strongly suggest you look at Napa, or an automotive supply shop for jack-stands. Don't go to C-T or Walmart. Spend a few extra bucks. This is a legitimate place to go overboard.
sithot 04-14-2007 06:32 AM
I'm glad you didn't get hurt in the mishap.
Made in China; Guaranteed (to break).
NEVER buy a piece of junk from the distributors of Chinese crap. This is not the first off-shore POS I've seen break.
If you can afford the car, you can afford a good jack.
Best,
Tom
Gunter 04-14-2007 07:38 AM
He is posting about a floor jack, not jack stands. :)
Gunter 04-14-2007 07:51 AM
Thanks for the heads-up and glad it isn't worse.
I made up something different for jacking:
7/8" key stock about 7-8" long with a 3/4" NC nut welded on and a short 3/4" bolt.
There is a jacking plate devise available for this but there is a great disadvantage: The jack arm can slip off the plate when lifting.
The key stock gadget is cheap to make and works better than the jacking plate. :)
The picture shows a bottle jack just for estra safety.
When lifting with a floor jack, I turn the key stock so that the 3/4" bolt faces down and rests in the cup of the jack arm.
http://forums.pelicanparts.com/uploa...1176562001.jpg
Porsche_monkey 04-14-2007 08:24 AM
My error. I still believe what I said applies to floor jacks and jack stands. Don't buy crap. Fork out some cash for Hein-Werner jack.
I would be equally suspicious of any Chinese floor jacks made of aluminum that are welded together. Aluminum is difficult to weld and given that the Chinese jack stands made of steel are failing I would never trust their aluminum welds.
P.S. That is a very good jack stand shown in your photo. It is what everyone should be using.
sammyg2 04-14-2007 08:35 AM
BS on the china bashing.
I've had american crap break on me too.
That is, if you can actually find american crap anymore.
There are good tools and bad tools. With a clue you can tell the difference most of the time, but just looking at where they were made will not do it.
Porsche_monkey 04-14-2007 09:31 AM
Fair enough, but the reality is the 'cheap stuff' is all made in China. And legal liability issues in the U.S.A. make in unlikely that a cheap/sub-standard jack or stand would be manufactured in N.A. Lawsuits are of no concern to the Chinese. And that goes double for the crap that is sold from the trunk of someones car, rather than through a real distributor.
So I will rephrase it to say don't buy cheap floor jacks or jack stands. If you find a 'Made in America' jack stand it could easily be crap too. And, it may be possible to find a good jack-stand or floor jack made in China.
When you buy a tool that could put your life at risk (or your limbs) look at what you are buying and think about the consequences. Caveat emptor.
vash 04-14-2007 09:36 AM
i bought a floor jack just recently...it is from a company called AMERICAN FOUNDRY. i swear, the thing is almost red, white and blue. it has a made in china sticker on it. i was bummed. my next floor jack is one of the high end ones that wayne sells. but i wont trust any floor jack enough to climb under a load.
haycait911 04-14-2007 09:37 AM
I won't post pics of the jack, I'm too embarrassed. it wasn't very good. maybe it's different in the states but in canada it's tough to find stuff made in canada or the us. craftsman, mastercraft, napa, ultrapro, etc. are largely made overseas. my car is clean because I just got it on the road, I drive it to work every day and as much as possible on the weekends. here is a pic of my stands, they are the only jackstand I truly trust. they were made by a machinist friend of mine. thanks for your concern. I also have/recommend a big block of wood that I put under the car when I'm working, just cuz. I should have the quarter in primer by the end of the day, paint it next weekend. Donhttp://forums.pelicanparts.com/uploa...1176568485.jpg
ps to gunter. I'll probably spot in the burnt paint on my wheel opening lips at the same time. putting on some fake 7" fuchs this weekend until I find some real ones.
Gunter 04-14-2007 09:53 AM
Don:
We need to see a picture, fezz up!
Next time you're at Canadian Tire, take a look at a floor jack called: "Michelin", about 2-3 ton?
Special at times for about $70.-
Not very low but not bad concidering the price and, it lifts up to about 23"
billroth 04-14-2007 10:05 AM
You guys are scaring me. I am about to get out my Canadian Tire jack and stands. The blue Michelin ones. I stayed away from the black and red Workforce ones. Any concerns with the Michelin stands or should I be shelling out big bucks for the AC stands sold by our host (a pay a fortune for shipping!)?
Lawrence
haycait911 04-14-2007 10:20 AM
I have a nice high lift 2-1/2 ton jack I picked up at princess auto but that wasn't the one I was using. I can't get a pic of the old jack, it's already in the scrap metal pile at work. it was like the ones you see at walmart that come with two equally fine jackstands for about $50. Lawrence, don't get freaked out, just look at the welds and if they seem questionably have somebody weld them properly for you. three words- BLOCK OF WOOD. get the offcut of a gluelam beam or similar. great peace of mind. how do you like your pit Gunter? I'd like to put one in but with our water table here it'd be more of a small swimming pool. Don.
Porsche_monkey 04-14-2007 12:04 PM
billroth - post a picture and will criticize the crap you bought.
haycait - look for a Hein-Werner jack, or buy an expensive one from Princess.
http://www.jackxchange.com/products/HW93642.cfm
