Curve Eater's Avatar
Rear Deck latch won't catch
Any ideas??
I tried changing the tension on the release wire, but no go.
It seems that, when in the correct position, there is a "half-washer" that catchs, but I can't get mine to do that now.
Please give a new brother a hand.
Bill
Old 04-15-2007, 11:12 AM
Danny_Ocean's Avatar
Did you change anything (new weatherstripping ,etc.)? Besides adjusting the "half-washer" (viewed when looking down the hole in the latch - female part), you may also have to adjust the "spear" (male part) that goes into the hole. This is adjusted by screwing in/out (hmm...I hope this isn't too graphic for a family-rated forum). Sometimes the "half-washer" gets gunked up and won't release completely. 1/16th of an inch out-of-whack will cause a failure to "hook up". Try spraying the female part with lubricant. (Vodka martini's usually do the trick for me)...
I had the same issue when trying to get my lid to close tighter. I did a search here and found an article describing the procedure in detail. Everything works great, now.
Old 04-15-2007, 12:10 PM
Well, I tried lubricant. No go.
How taut shoud the release wire be? And should the "half washer be visable when the deck is open?
Old 04-15-2007, 12:21 PM
Got it!! It truly takes a village....
Thanks guys
Old 04-15-2007, 01:17 PM
