ER Poly-Bronze bushing install problem.
I'm in the process of changing to the ER bushings. On the rear, I've put everything together but now the bolt holes don't line up.
I ground the T-Bar tubes flat and all seems to be square. If you hold the spring-plate cover out far enough you can start the bolts but they tighten up against the cover and then everything binds up. If you put in the top two it seems fine but the bottom bolts don't line up. What did I miss, and what do I need to do? Thanks |
Put washers in as shims to move the cover plate out far enough so that it doesn't bind up the spring plate. See if that also helps with the bolt alignment. Good luck.
Marv Evans '69 911E |
Used the shims and even added an extra and still no good. I've pulled one of the inner bushings back out and will try to "index" it to the springplate and cover.
Thanks though. I appreciate any help I can get. Doug |
Regis turd ab user
You might have gunk on the splines in the torsion tube. Is it happening on both sides? The torsion bars butt up to each other internally
Haven't installed the bars yet. Wanted to make sure everything worked smooth first. It is happening on both sides.
I've pulled the right side back out, removed the calking and put it back in. It's better but still a little stiff. So, I ground down the torsion tube even more to try and make sure it's even all the way around. I'll see if that helped more and then recalk. Thanks for the help. Doug |
PRO Motorsports
The spuds for the mounting bolts are notoriously inaccurate.
You can put in a sacrificial bolt, and try to leverage on it to straighten the spuds. It takes a good eye, and some patience. Also a good time to check for cracks around the spud welds. Very common.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3 |
Had this problem on one side but was ble to get bolts started with cover all the way out.
Chuck Moreland was very helpful throughout the installation process. "V" |
I am sure Chuck will say something when he sees this post. He seems to know a lot about this product.
James 1969 911E Slate Grey 1981 911SC Wine Red 1997 911C4S Ocean Blue |
I've called Chuck and spoken with him on the phone, during business hours, of course. I didn't need help with my installs, but I know he will have good insights. Give him a call Monday AM!
Jake Gulick, Black Rock, CT. '73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B] |
Yeah, I have called Chuck on the phone too and found him to very nice and helpful.
You can probably find the number at elephantracing.com.
Thanks Everyone,
I think I've got i it figured out but I'll give Chuck a call. Cheers |
