-   -   1978 model yr weakness' (http://forums.pelicanparts.com/porsche-911-technical-forum/342879-1978-model-yr-weakness.html)
gwl123 04-23-2007 05:52 PM
Looking to buy a 1978 SC but would like to know what the problem areas are for this particular Calif. yr model. I understand even though they are "bulletproof" they do have problems such as broken studs. Also did they still have the thermal reactors for Calif. smog control?
the 04-23-2007 05:57 PM
No SC's came with thermal reactors. It came with a smog pump, EGR and 2 way cat converter.
gtihop 04-23-2007 06:32 PM
check for broken head studs, tensioner upgrade, do a leakdown and comp test. A good ppi from someone knowledgable about porsches should check most of the critical areas. also check for rust. And keep in mind, it's a 29 year old car, it will need work.
