Question 1978 model yr weakness'
Looking to buy a 1978 SC but would like to know what the problem areas are for this particular Calif. yr model. I understand even though they are "bulletproof" they do have problems such as broken studs. Also did they still have the thermal reactors for Calif. smog control?
Old 04-23-2007, 05:52 PM
the the is offline
No SC's came with thermal reactors. It came with a smog pump, EGR and 2 way cat converter.
Old 04-23-2007, 05:57 PM
gtihop's Avatar
check for broken head studs, tensioner upgrade, do a leakdown and comp test. A good ppi from someone knowledgable about porsches should check most of the critical areas. also check for rust. And keep in mind, it's a 29 year old car, it will need work.
1983 911 SC
2015 Volks GTI
1991 Volks GTI
2011 Nissan Juke
1992 Nissan NX 2000
Old 04-23-2007, 06:32 PM
