Shaun @ Tru6's Avatar
Would your early car pass the screwdriver test?
My early suspension refresh turned total restoration couldn't have come at a better time. I cleaned out the motor bay today and what looks like nice, hard, solid factory undercoating is really a dry, brittle nightmare hiding rust and the potential of trapping water under it. I was going to just run some POR15 over the surface, paying attention to some areas where it flaked off. On closer inspection, and some LIGHT scraping with a flathead screwdrive, it just comes off in large flakes, VERY EASILY! I think if I had left this for only a year it would have meant a lot of welding. Now it's just surface rust.
Anyone looking at an early car purchase should fully inspect all underneath surfaces very carefully. BTW this was a CA car all its life.
Tru6 Restoration & Design
Old 04-22-2007, 03:01 PM
Designer King
Paulporsche's Avatar
Good catch!
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 04-22-2007, 03:03 PM
I'll soon find out as I pulled the motor yesterday.
Robert
Currently Porsche less (but the wife has 2)
Old 04-23-2007, 05:51 AM
ttweed's Avatar
Re: Would your early car pass the screwdriver test?
Originally posted by Shaun 84 Targa
On closer inspection, and some LIGHT scraping with a flathead screwdrive, it just comes off in large flakes....
This has been the case with every early car I have ever had, no matter where it spent its life. It's when the screwdriver pokes through the metal that you have a problem! At least the metal is sound in the places you have uncovered.
I use a flat-bladed scraper to lift and remove all the loose coating at the margins of the bare areas, widening them until I get back to bright metal and well-adhered undercoating, then a stiff wire brushing to remove the surface rust, then clean with degreaser, apply the metal prep treatment for 20 minutes, rinse, dry, and apply two coats of POR-15, topped off with new undercoating, and you're probably good to go for another 35-40 years.
TT
Tom Tweed
Early S Registry #257
R Gruppe #232
Rennlist Founding Member #990416-1164
Driving Porsches since 1964
Old 04-23-2007, 06:19 AM
Non Compos Mentis
I got real lucky. Bought my '73 at an auction where I couldn't thoroughly inspect for rust.
Got it home, started taking the interior out, not knowing what I'd find, and there was zero rust. Pretty amazing. Bare metal repaint since then, so I know I'm in good shape for years to come.
Old 04-23-2007, 06:35 AM
This much less of a problem on 1970 and later cars, because at least the floor pan and some of the internal panels were zinc coated. The difference is dramatic.
Old 04-23-2007, 07:04 AM
T77911S's Avatar
also check around and under the gas tank and front suspension.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 04-24-2007, 08:58 PM
I just inspected my engine bay in detail (with the motor out) and I couldn't believe how rust free it was.
These are great cars-- nice to see you taking that type of care. Definitely worth it.
1972 911T targa
Old 04-25-2007, 05:20 AM
I too found the area of rust in my early car. The rest was so rust free but when it came to that corner and a hood seal going bad allowing water to not run off the car it rusted the front hump bad.
Old 04-25-2007, 05:31 AM
(the shotguns)
berettafan's Avatar
Tom thanks for answering my question before i even asked it!
Old 04-25-2007, 05:50 AM
Todd Simpson's Avatar
Shaun-
This is a regular routine for me on my '71. The latest area I treated was the front subframe mounts. Lots of nice undercoating just came off in huge flakes. The front suspension, battery area, rockers, floors and engine compartment all have been checked and treated previously.
Check the *inside* of your torsion tube as well.
Old 04-25-2007, 07:39 AM
lateapex911's Avatar
Tom hit the nail on the head. The other method is to strip it bare, shoot self etching primer on the bare metal, then primer, then color, then undercoat, Or use body shutz intead of undercoat, then color on that.
Jake Gulick, Black Rock, CT.
'73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B]
Old 04-25-2007, 08:16 AM
