-   -   Tire question-not which one should I get! (http://forums.pelicanparts.com/porsche-911-technical-forum/343530-tire-question-not-one-should-i-get.html)
dweymer 04-27-2007 08:44 AM
I am looking at different tires for my 74. I am running 22/28 t-bars, height is 24.5f, 24 rear. I run 951 7's in the rear and 6 up front.
The question is this:
Hankook lists the Z212 as:
225/45-16 section width: 8.9, tread width:8
225/50-16 section width: 9.1, tread width:7.6
Why would a tire having a wider section have a narrower tread?
Edit: link to pdf data:
http://www.hankooktireusa.com/product/Z212.pdf
Dantilla 04-27-2007 09:03 AM
Most tires buldge out somewhat. Overall width is usually wider than the true contact patch.
dweymer 04-27-2007 09:27 AM
Right but these are both the same width, just different aspect ratios...
