Tire question-not which one should I get!
I am looking at different tires for my 74. I am running 22/28 t-bars, height is 24.5f, 24 rear. I run 951 7's in the rear and 6 up front.
The question is this: Hankook lists the Z212 as: 225/45-16 section width: 8.9, tread width:8 225/50-16 section width: 9.1, tread width:7.6 Why would a tire having a wider section have a narrower tread? Edit: link to pdf data: http://www.hankooktireusa.com/product/Z212.pdf
Donnie Currently Porsche-less.....
Non Compos Mentis
Most tires buldge out somewhat. Overall width is usually wider than the true contact patch.
Right but these are both the same width, just different aspect ratios...
