-   -   CIS initial pressurization question (http://forums.pelicanparts.com/porsche-911-technical-forum/343809-cis-initial-pressurization-question.html)
914efi 04-29-2007 08:11 AM
I'm having some cold start flooding problems, and noticed that when the system first pressurizes after sitting overnight that a small burst of fuel comes for the injectors. This does not happen if you start the fuel pump after the system is at pressure.
Car is a '75, so fuel pump starts with key on. Control pressures are all normal.
Is this normal?
jess p 04-29-2007 08:23 AM
efi
It sounds as if the cold start timer is at fault.
76 911S
81 911SC
66 912 v8
71 914 project car
