CIS initial pressurization question
I'm having some cold start flooding problems, and noticed that when the system first pressurizes after sitting overnight that a small burst of fuel comes for the injectors. This does not happen if you start the fuel pump after the system is at pressure.
Car is a '75, so fuel pump starts with key on. Control pressures are all normal. Is this normal?
Art '75 911 US Carrera #390 '74 MGB, AH 3000 BN7 V8, '65 Mustang Fastback, 66 bronco U13 |
efi
It sounds as if the cold start timer is at fault.
76 911S 81 911SC 66 912 v8 71 914 project car |
