I like Orange
Cookie Porsche's Avatar
Aluminium Discs ?
I have a set of aluminium discs (aluminum rotors!) with 993 style hats and a box full of 'special' pads for these discs / rotors.
After searching this board and the www with few results I have a few Q's.
1) Besides them being ultra light (they are cross drilled too)...
2) Would they work in a race application?
3) Could I use normal pads (ie pads for steel discs)
4) Are there any safety concerns
My car is currently running the 993TT steel discs so it would be a straight swop.
Regards, Tom
“Rules are meant to be interpreted…”
http://www.cafe9.co.za
Old 04-29-2007, 09:36 AM
Banned
Must be the Metal Matrix stuff from George Velios, no longer making them, they were good, they vibrate a lot when you apply hard on the pedal, I use to use them on street applications, probably will work best on a racing app., I too have some laying around!, Candy.
Old 04-29-2007, 05:40 PM
Bill Verburg's Avatar
Maybe for street use where the don't get very hot, but on track they would melt and transfer material to the pads. Instant junk
Bill Verburg
Old 04-29-2007, 05:58 PM
Diss Member
Quicksilver's Avatar
The metal matrix composite is some strange stuff. It keeps almost all of its ultimate strength right up to the melting point of the aluminum then it very quickly fails. Very wierd.
Not sure how it holds up but I suspect that there is no way that it could absorb as many BTUs as cast iron so under heavy punishment the discs would self destruct. I would guess that when they go it would be a much more complete failure then we are used to seeing. (Anyone up for some excitement? If so please post pics.)
If they would hold up to real punishment someone (a lot of someones!) would be using them on the track.
BTW - How much did they cost?
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 04-29-2007, 07:05 PM
Banned
I hear that they did hold pretty good, I never like them on street, never try them under race cond., there is a following for them I hear, they weren't just aluminum per se, that is where the "matrix" comes in, actually it was an alloy from alum./syli,(Alusil, kind of)., very hard stuff, you will need diamond cutters in order to turn them. Candy.
Old 04-29-2007, 09:14 PM
I like Orange
These discs came from Europe. I bought them from a friend and don't know the original price.
The rotors are mounted on a different type alu hat, thus both front and rears are floating.
If not good for racing they may be ideal for a drag Porsche!
I will post pics on Wednesday (on holiday...).
Regards, Tom
Old 04-30-2007, 06:17 AM
Senior Member
Superman's Avatar
In my opinion, this sounds like a description of the worst possible braking system.
Mocha 1978 911SC. "Coco"
Old 04-30-2007, 08:47 AM
id911T's Avatar
And your opinion is based on Bill's opinion, which doesn't sound like he has any direct experience with this particular brake setup.
Stephen
GruppeB #906
1970 911T
Old 04-30-2007, 08:57 AM
I like Orange
So then. This raises the next few questions.
1) What is the critical temperature these alu discs can handle? I mean - do they 'melt' like a marshmellow at 500 degrees or well in excess of the normal 600-700 degrees that is considered a spike.
2) Anyone here with actual experience?
The chap I bought the discs from races a 993 GT2 EVO (same class as me) and is known ONLY to buy from Weissach directly. He has subsequently retired from hardcore racing and that's how I got the discs. I do believe they were VERY expensive.
Image the advantage of this weight saving. My car is already very light but I run against some very fast cars and every little 'advantage' is welcome.
Regards, Tom
Old 04-30-2007, 11:20 AM
