-   -   My electric windows work without the key in the ignition (http://forums.pelicanparts.com/porsche-911-technical-forum/344722-my-electric-windows-work-without-key-ignition.html)
KatoKato 06-05-2008 06:40 PM
Originally Posted by rick-l (Post 3978537)
No... to hold the contacts closed requires a magnetic field which requires a current flow through a coil - the relay is then referred to as energized. The current flowing through the relay causes power to be dissipated in the coil resistance
So it wouldn't matter what I have connected to the circuit ---- if the relay is faulty and energized as a result, the battery will be drained eventually?
rick-l 06-05-2008 07:52 PM
Not necessarily. Consider the relay coil like a light bulb. If you complete the circuit from the positive battery terminal to the light bulb (relay coil) and back to the negative battery terminal current will flow, the light bulb will light (coil energize) and energy will be consumed.
In the simple relay system shown above this path is completed when the doors are open and the light switch provides a ground to the relay coil.
In the more complicated part the ground is provided with semiconductor logic circuits and if the logic is hosed it will be turning it on.
avt007 06-09-2008 06:17 PM
here's a schematic of my relay. Pardon the quality, most was done on RFFlow, the last couple bits in MS Paint. When the key is on, current flows through D1, and the coil of relay K1, closing the relay contacts. This sends power to the window switches. Current also flows through R1, and D3, again to the coil, which holds the relay closed when the key is turned off. This continues until either door is opened. The door switches ground the circuit, dropping all the voltage across R1, relaxing the relay. Since my door switches don't work, the relay stays on all the time, drawing current from the battery, through R1, and the coil of K1, until eventually the battery dies. I unsoldered D3 as a temporary fix. http://forums.pelicanparts.com/uploa...1213060630.jpg
rick-l 06-09-2008 09:14 PM
I take it this is relay 944 615 116 00.
The 87-89 PET (my car) does list 944 615 112 02 (illustration 902-00) pos (7) but the picture dosen't look like the relay I have.
  • I wonder which relay I should have
  • I wonder why they changed the relay and not the owners manual.
A search of Pelican shows both relays
OEM-94461511202 Genuine Porsche Part: RELAY
- This is a special-order, non-returnable, Porsche part
(availability and shipping charges may vary).
944-615-116-00-M100 Electric Window Relay, 944 All (2/85-91), 968
Originally Posted by avt007 (Post 3993434)
avt007 06-10-2008 02:28 PM
Yes, my relay is p/n 944 615 116 00. Build date 12/85. As to why Porsche kept changing things, I don't know. Next step for me is pulling the door switches and seeing what I can do with them.
aj88cab 06-10-2008 03:34 PM
My '88 Cab doen't have either of the relay types installed. So I searched many threads about this function and have decided that the Cabs got the 944 615 112 02 relay to allow operation of the windows with the door open as a feature for raising and lowering the cab top. The Coupes got the 944 615 116 00 relay to allow for closing the windows and sunroof after you shut off the engine but are still in the car. I didn't find a pattern regarding Targas. And I'd be curious if there was a difference between manual and motorized cab tops too.
As a note, I think my relay might have been removed when the aftermarket alarm was installed by the PO. The system uses the door switches as one trigger for the alarm and I am guessing the convienence relay would cause problems with that. Just guessing though.
avt007 06-12-2008 10:55 AM
I feel kinda silly now- after all this work, the fix was to pull the door switches out and polish them up with Scotchbrite and put them back in. 10 minutes work, and all is well. BTW, this definitely fixed my battery problem. She starts fine after sitting for a week or two. Thanks to all the help from this forum.
rnln 04-14-2009 12:07 PM
Rob,
Can you explain a little detail of "polish them up"?
Thanks.
darrin 04-14-2009 12:47 PM
on my '86 targa, the driver's side pin switch would not reliably cause the interior lights to turn on (and, therefore, would not deactivate the power-draining relay for my electric windows) when I opened my driver's side door.
Although I ended up replacing the switch with one purchased from our sponsor, after removing the old switch I found that a bit of corrosion on the surfaces that are supposed to meet when the switch is closed (door is open) was preventing the switch from closing completely. It's easy to see and understand once you remove the switch and I believe that Rob was simply referring to cleaning the contacts on the back of the switch with scotchbrite, etc. to expose bare metal on the contacts and again allow the contacts to work. Or, you can simply replace the switches . . .
dshepp806 04-14-2009 01:11 PM
Originally Posted by rnln (Post 4606009)
Rob,
Thanks.
I would guess "burnish" (if you will) "nice shiny metal"......then a good coat of what's necc.
Best,
Doyle
rnln 04-15-2009 01:24 PM
did you guys have to take the door panels off to pop the switch out, or just pry it out?
Thanks.
avt007 04-15-2009 01:40 PM
There's no need to touch the door panel, it's the switch in the door jam that controls the interior lights, that we're talking about. Pry the rubber cover off, undo the switch, and pull it out. You'll see how crude the switch design is. It's a good thing though, it makes it easy to fix. Seen here-
http://www.pelicanparts.com/cgi-bin/smart/more_info.cgi?pn=928-613-147-00-M100&catalog_description=Door%20Light%20Switch%20% 28%32%20per%20car%2C%20sold%20per%20each%29%2C%20% 39%31%31%20%28%31%39%38%30%2D%38%39%29%20
kidrock 04-15-2009 02:21 PM
Thanks.
rnln,
I recently fixed this little problem...very simple. The switch is located on the front door jamb, and can be removed by the center nut. Gently pull the switch out of it's mounting hole, and gently clean every contact point with a small brass brush (or whatever). Also clean the switch mounting hole, as it acts as a ground. It is usually dirty or corroded, and is usually the main source of interior lighting problems.
Put a small dab of di-electric grease on the contacts, and gently re-assemble.
rnln 04-15-2009 02:49 PM
oh ok. You meant the door switches, not the power window switches.
Thanks.
chammond 07-03-2010 08:18 AM
Hi there...I just bought an '88 911 coupe and have a battery drain issue. I'm battling this electric window problem (they always work when the key is out of the ignition and after I open any of the doors). I've cleaned the door switches that trigger the interior lights, one of them was bad and now the interior lights work as they should. This did not fix my problem as the windows still work when the ignition is off and the doors are open so I figure my power window relay is a in need of replacement.
My question is, where is the power window relay located? I have found part number: 944-615-116-00 (i've attached a pict) on PP that seems to go in the fuse box in the bonnet, but I've read that others are talking about a relay that is behind the instrument cluster.
http://forums.pelicanparts.com/uploa...1278170081.gif
I'm a noob in the DIY dept, but am really getting into troubleshooting the smaller stuff that I can handle but this one is driving me crazy.
Is this the correct relay to replace?
BTW, here's a picture of my new car. I am absolutely in love with it!
http://forums.pelicanparts.com/uploa...1278170257.gif
http://forums.pelicanparts.com/uploa...1278170278.gif
Thanks,
Chris
86 911 Targa 07-03-2010 09:11 AM
Thanks,
Chris
Chris,
Here you go............
Good luck,
Gerry
http://forums.pelicanparts.com/uploa...1278173435.jpg
chammond 07-03-2010 09:20 AM
Thanks Gerry...it this relay accessible from the front bonnet or do I have to pull the gauges in the dash and get to it from the front?
Chris
86 911 Targa 07-03-2010 09:35 AM
Chris
Chris,
Best to pull the steering wheel, then the gauge.
But first, how do you know It's the relay?
Gerry
chammond 07-03-2010 09:41 AM
I don't for sure...I have to check the current across all of the fuses to see if the drain is caused from something else.
I have read numerous posts about the power window operation on these cars and for some reason the power to my windows is always there, even with the key out and door(s) open. I cleaned the door switches that operate in the interior lights and they are working properly.
I'll meter across each fuse to see if there is something abnormal and go from there.
Thanks,
Chris
porschenut 07-03-2010 01:59 PM
Don't bother pulling the gauges until you've tried reaching the relays from the open trunk. Just stick your arm back there - I've never had any problem plugging or unplugging them this way.
By the way, "bonnet" means lid. The trunk is called a "boot" in UK/Europe.
