I am searching for some sort of hardware Diagnostic Tool for use with my 1986 3.2 Carrera.
I have looked at: ScanTools AutoEnginuity ScanGauge OBD-II Standards I know that what I am searching for is, in all likelyhood an OBD-I aftermarket scaner/reader. The connector for the 'brain box' is a 35-pin out test harness (Porsche OEM 00072195430) which, I believe, is *not* in any way compatable with OBD-II reader/scanners which I have looked at. My question is this: What devices, if any, are available to diagnos my 1986 Vehicle? |
Autobahn Garage
Bosch Hammer
T Tanner 76, 911s w/ Webers 76, 914/4 57, Speedster |
I believe the hammer is for the 964 and later cars. There is not a port on a 3.2 to plug a tool in. You need a manual and multimeter to test all of the components...
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
took me a while to find this but here it is
also the hammer thing is correct, but a box is cheaper at least this is what i remember, ask steve (either W ) or loren for the absolute truth good thread here DME breakout box - where can I get one? and here's where you can find a box and a cable http://tools.baumtools.com/index.jsp?index=1&newIndex=1&menu=por |
Irrationally exuberant
There is no scanner tool for the 3.2L ('84-89) 911.
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
I've put over 160K miles on my '85. It has never failed California smog test (now at 178K) including a dyno test few weeks ago.
Maintenance the "old fashion way" ...you learn it... ![]() Overall I have found the ignition/fuel/DME quite reliable and tolerant. Sure some injectors got clogged, a DME relay went bad once, O2 sensor was dead for probably 80K miles |
