Happiest when Tinkering
gsmith660's Avatar
There is a better pad out there that has edgeing.
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go!
76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3
76 Blazer also restored by me
Old 01-04-2009, 06:32 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #661 (permalink)
Bird. It's the word...
Fishcop's Avatar
Originally Posted by fbarrett View Post
By the way, if you want to do a book, which would offset your expenses for this project, I volunteer to be the editor! Bet I could find you a publisher, too.
Frank
Toad Hall Motorbooks
303/237-0911
I'd certainly be a buyer!
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 01-05-2009, 01:02 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #662 (permalink)
Gotta ask, what carpet kit did you use??
Love your thread!
Greetings from Sweden.
Mike
Old 01-05-2009, 08:52 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #663 (permalink)
Grady Clay's Avatar
Lars,
Absolutely take Frank up on his offer.
"How to build a 911 from scratch." would be a bestseller.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 01-05-2009, 09:26 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #664 (permalink)
911 tweaks's Avatar
I too would buy a couple of editions... 1 for the shop and 1 to keep on the shelf w/o grease and crap all over it as the shop one would become aiding my resto project.
Bob
I live for 911 tweaks...
Old 01-05-2009, 11:49 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #665 (permalink)
tb912's Avatar
it's probably rude to ask, but I'm dying to know how much $$ you are in on this project. it is truly extraordinary. I hope one day in many years i'll be capable...
Old 01-09-2009, 02:06 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #666 (permalink)
Rennch on YouTube
rennch's Avatar
Send a message via AIM to rennch Send a message via Yahoo to rennch
Knowing Lars, he's probably made money on it. (His hours notwithstanding)
Michael O'Neal -
69 RSR Clone(ish) - The build: http://bit.ly/69porschersr
69 911S Blasphemy Build on YouTube
Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/
Old 01-09-2009, 03:08 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #667 (permalink)
rear end attention
The rear bumper was fit prior to painting and requires a small effort in fitment, then to be bolted up
I had the remove the tailights to get decent access for mounting the bumper
I mounted it temporarily...and ran tape around the outline of the rear lower quarter.
I then remove the bumper and use the outline of the tape to run my rubber seam...finished product
sits nicely and keeps the steel from chewing up the fiberglass bumper
completed...bumpers done, on to the exhaust
Old 01-10-2009, 05:51 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #668 (permalink)
gsmith660's Avatar
You are not going to know what to do with yourself after you get done with this, great job and love that color.
Old 01-10-2009, 05:55 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #669 (permalink)
Muffler time
I did a search and found that the R muffler outlets were 2 3/4" od vs the 2" "pea shooter sport exhaust outlets. Based on how the inlets line up with the outlets underneath the rear bumperettes...it becomes basically a straight pipe. This will be a street car, and straight pipes will be too loud. I'll need to do some mods to the inside of the muffler to avoid and remedy the straight pipe issue. I mount the muffler and mark for the outlets
I don't have the 2 3/4 pipe, but I have 2 and 3 inch...here is the look for comparison
...the 3 inch seems enormous
This has got to go
With al do respect for the purists...I am not a fan of the 2 in 3 out option where you cap off the two R outlets for the street, and cap off the oem street outlet and uncap the sport outlets for the track. Just looks like one too many appendages.
Bye bye
Old 01-10-2009, 06:08 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #670 (permalink)
git'r done...
I bought 2 1/2 steel pipe, and 3 inch (local muffler shops don't carry 2 3/4) and I decided that after looking at the 3 inch which I was going to split and reweld back to 2 3/4...that the 2 1/2 was going to be just fine. As the original R muffler didn't have the left side outlet sawed off and welded over...it had the same continuous seam around that end of the exhaust...I decided to retrofit the same thing. I want this end
To look like this end
I started with this
to this...rough to start
I needed to section in slightly to get it to conform to the curve of the end of the muffler
Welded up...this will clean up nicely
The seam will be just like the other end...and not just "capped off"
Old 01-10-2009, 06:23 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #671 (permalink)
Show time...
I decided that the 2 1/2" outlets were big enough...holes first. Pullled out my jigs for modifying the muffler
Mounted up, this will allow me to secure the muffler and get proper alignment to weld up the outlets
I'll drill the holes
You will notice that the end of the muffler has a "cavity" at the ends
These need to be perforated , so I pulled out the cutting torch and went to work
other side
I needed to fit the 2 1/2 inch outlets
Old 01-10-2009, 06:52 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #672 (permalink)
And done...
Tacked up
Check the alignment and weld.
Looks good...now the litmus test
Tailights go back in, grill gets mounted to deck lid tomorrow.
I'll pull the muffler and get it Jethot coated.
Speedo
Old 01-10-2009, 07:02 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #673 (permalink)
zotman72's Avatar
You are going to put a heat shield between the muffler and the rear bumper right? Perhaps reflective asbestos matting. Hate to see that pretty paint get scorched by close proximity to your muffler. YMMV
Bill
'72 911T-2.4S MFI Vintage Racer(heart out), '80 911SC Weissach,'95.5 S6 Avant Wunderwagen & 2005 997 C2S new ride.
Old 01-10-2009, 07:12 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #674 (permalink)
gsmith660's Avatar
So hows it sound?
Old 01-10-2009, 07:23 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #675 (permalink)
jpahemi's Avatar
Lars,
Who makes the clear windshield? Sigla??
Regards,
jp
Old 01-10-2009, 10:00 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #676 (permalink)
Can You just do that to the muffler.....? How does this affect the performance?
Will it boost HP like the sport mufflers?
Jon S
911L SWT Euro-version
Old 01-13-2009, 10:47 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #677 (permalink)
signature65's Avatar
The detail work you do is awesome.....truly an inspiration for us out there.
Who on earth would continue the seam around the muffler......
Darren
1973 911 T MFI
2005 997 Carrera
2001 Toyota 4Runner
Old 01-13-2009, 11:29 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #678 (permalink)
onboost's Avatar
+1 That was a very cool detail...
RGruppe #180
Old 01-13-2009, 12:13 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #679 (permalink)
911 tweaks's Avatar
... lars would... has to be just so...can't you tell from the rest of his build !!
Hey Lars, I hope you do sign up to do the book offered to you it appears... us mortals would very much enjoy the read and I am sure many tips on how to do things correct would be in there!!
Bob
Old 01-13-2009, 12:17 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #680 (permalink)
