unique parts request - brake ducts (cross post)
Hello,
I have found almost everything I need on this BBS for my recently purchased 72 Targa. I might need a few more things: - The car has 85 body parts, including the lower front end with fog light holes and mounts. Currently there are no fog lights mounted and was thinking about running some kind of brake and oil ducting for cooling. Does anyone sell or fabricate something like this that would also dress up the fog light holes? - The car has a 3.2 transplant and probably needs a front oil cooler and lines. Anyone have a bolt on setup that would work (the 72 911 T did not have a front cooler or lines for one)? TIA! Scott
72 911 T Targa in Orient Red / Black - more like a 85 Euro RS IROC now - 85 Euro 3.2 with x-faktory EFI ITB + SSI + Dansk, 915 + Wevo, flares + IROC bumpers + duck tail, RS door panels, Corbeau LG1 microsuede seats, Speedware harness bar + drop links + Scroth DOT harnesses, adj Tarett sways, sport shocks, alloy trailing arms, Elephant Racing oil lines + spring plates + bushings, RSR Rota Foxes + Bridgestone S-04 PP, 2450 lbs |
bump
For the PNW you could probably be just fine with a stock Carrera cooler in the front right fender. You will also need the hard lines and thermostat in the right rear fender well.
Might be worth a consult with John Walker on exactly what you need and then go parts shopping. As far as the fog light holes go, how about actual fog lights? I hear it rains there occasionally.
Tony G 2000 Boxster S |
MBruns for President
smart racing sells the brake cooling ducts -
how about a picture (of the front of the car) and maybe we can help you -
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
