Mitch Leland's Avatar
Spare Tire...
Howdy, another question for the "P" Brain Trust... What do y'all do for air for the spare tire? I guess the three options would be:
1. Do nothing because Porsches don't get flat tires.
2. Aerosol air can.
3. 12V air pump, if so who's do you recommend?
4. Other...
Thanks,
Mitch Leland
"03" 996 C2S-LS3 V8-480 HP
"84" 911 Turbo Look-Sold w/ found memories
Old 05-11-2007, 05:08 PM
Zef Zef is offline
THE IRONMAN
Zef's Avatar
OEM compressor...look good in the fwd trunk and work very well...!
1984 911 CARRERA RUBY RED TARGA
SW CHIPPED-BURSCH CATBYPASS
MONTY FREE FLOW EXHAUST
<IN GAS WE TRUST>
Old 05-11-2007, 05:41 PM
I recently took a Pelican Poll regarding the spare. I am thinking about going without one, and replacing it with a plug kit and two cans of fix a flat. I also have a foot pump from Sears that works very well. My car didn't come with the compressor.
Black 1985 Carrera ~ Whale Tail - Gone but not forgotten
2013 Boxster - Wifey Car
1969 Karmann Ghia - Next in line for restoration
"Driving in its most beautiful form"
Old 05-11-2007, 09:45 PM
slodave's Avatar
Don't use fix-a-flat. Terrible stuff. I used it once with success, but the second time, it did not coat correctly and I had a 375 mile uncomfortable ride. The plugs are a good idea for roadside temp repair. Always have it patched.
BTW, my spare is leaning against my stairs in my house - yes, I am a bachelor.
Dave
Old 05-11-2007, 09:50 PM
Diss Member
Quicksilver's Avatar
You don't want to use fix-a-flat on the spare. It is reusable and needs to be collapsed to put back in the car. If you fill it full of some sort of tire goo it is going to mess up its insides.
Fix a flat is for tires that get replaced (semi)regularly. The spare doesn't get replaced so it would just sit there for years with that glop inside it.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 05-12-2007, 12:24 AM
chrisp's Avatar
AAA
'83 SC
Old 05-12-2007, 06:03 AM
mack6820's Avatar
I agree. I used to work at a tire shop. FIX-A-FLAT is some bad stuff. It will eat away your rims over time and also will throw off your balance.
Certified Southern Dumbass!
83 911SC with 993 conversion,
98 Ford Expedition 4WD lifted beast, 98 Jeep Grand Cherokee, 01 Ford Taurus, 99 Nitro Bass boat, and a riding lawn mower
Old 05-12-2007, 07:41 AM
Since we're on the subject of collapsible spare tires, does anyone know who sell's and mounts them??? My tire is 34 years old and probably doesn't work or, if I inflated it, it would probably rupture due to crakcs
___________________________________________
2001 Boxster S, Orient Red Current Vehicle,
1973.5 911 full factory "S" trim with a 3.2 engine **Sold**,2002 996 **Sold**,1975 911S **Sold**,
1971 911T **Sold**, 1968 912 **Sold**
Old 05-12-2007, 08:08 AM
Non Compos Mentis
I just used three old inflatable spares to move a parts car around. All three inflated just fine, with no leaks or cracks.
Old 05-12-2007, 08:16 AM
Thanks,
I think rolling around a parts car probably didn't put too much stress on those tires, as opposed to freeway speeds.
I think getting a new tires is probably one of those "piece of mind" things?????
Old 05-12-2007, 10:33 AM
I carry two large cans of Fix-a-Flat, no spare. If I ever have to use them, I'll dismount the tire as soon as possible, clean it out completely, clean the rim, fix the leak and be no worse of than I was before I used the stuff. F-a-F is only bad if you use it to actually fix the flat permanantly.
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 05-12-2007, 12:30 PM
