-   -   adjusting front height (http://forums.pelicanparts.com/porsche-911-technical-forum/345451-adjusting-front-height.html)
philippeF 05-08-2007 08:08 AM
Hello
I've got some troubles to ajust the front height on my '72 S
the screws to set the height (front) are on the max position, but i can't lower more the car. (still 2 inches between tire and body)
I have bilstein "track" shocks in boge struts.
Shall i reindex the bars or wait to drive the car till it lowers a bit ?
regards
Philippe
dweymer 05-08-2007 08:26 AM
I don't think it will settle that much, since the fronts are easy, re-index them 1 tooth and drive that to see where it leaves you. Also, be sure to set the adjustment screw around the middle, that way you can go either direction when it's settled.
Gunter 05-08-2007 08:26 AM
You answered your own question:
Gas-pressure shocks will settle a little more after you lifted the car.
If not, then re-index the front T-bars.
philippeF 05-08-2007 08:30 AM
thanks for the quick feedback
do you remember a post where it's explained ?
Philippe
safe 05-08-2007 10:57 AM
Just remove the adjuster screw and pull of the end cap (that the screw goes throu), reset the end cap in another position that alows a lower ride hight (anticlockwise I belive on the drivers side.).
