(the shotguns)
berettafan's Avatar
experiences with performance products replacement gas tank
Anybody actually install one of these? I'm concerned with a) fit and b) compatability with webers.
thanks,
erik
Old 05-11-2007, 11:48 AM
gestalt1's Avatar
i bought one for my 72. i got the early style for a full size spare. it fits fine and came with a zinc paint coating. the filler tube does not line up correctly and no hardware is included. great price however. for the fitting on the back i used 18mm to 8-an adaptors with 8-an to 6-an reducers. from the reducers i used 6-an socketless fuel lines for the send and return lines. there is also a drain hole that i used a 14mm bolt to seal it up.
-matt
BMW 128i
73 rsr clone - sold
68 912 project to become 911r (almost done!)
Old 05-11-2007, 03:10 PM
(the shotguns)
berettafan's Avatar
matt do you know if the tank had a 'swirl pot' inside or is it completely empty?
also, how out of whack is the filler tube and how did you fix it?
Old 05-11-2007, 04:47 PM
gestalt1's Avatar
i think it is empty, but i'm not really sure. i cut some of the fill neck off and used a longer hose to connect to the fill neck.
BMW 128i
73 rsr clone - sold
Old 05-11-2007, 05:04 PM
