8 mm triple square 'socket'
I know of two places on our cars that use a triple square tool (like an Allen) - the door striker plates & the flywheel bolts (at least on the 3.2L motors).
But what size do they take? Is it 8 mm or 10 mm? I'm asking because I have a chance to buy an 8mm one for a decent price used but don't want to do so unless I need it for the car. Thanks. |
I can't remember either. I think it is 10mm. Either way, Sears sells them.
The flywheel tool is 12 mm.
For what it's worth, Targa top latches employ triple-square bolts (can't recall the size). Brian |
triple square? is that what it is called? damn, i have been calling it the "12 pt, similar to a torx/ allen socket, thingy".
On my car, the flywheel bolts were 12mm and the pressure plate bolts were 10mm. They both were a biatch to get off. Personally I think triple square sockets are idiotic and should be banned. What is wrong with a hex nut????
Triple Square is stronger. Never use a Torx (or Bristol spline) both of which look similar - none of these interchange.
Thanks for the answers: 8 mm triple square - door striker plates 10 mm triple square - clutch pressure plate cap screws (some years) 12 mm triple square - flywheel cap screws (some years) |
Don't forget the CV joints, although in later years, Porsche went to hex, which requires more fiddling with your torque wrench when you tighten them up.
triple square - a square has 4 corners * 3 = 12 points |
The door striker plates are 8mm triple square...
| All times are GMT -8. The time now is 09:09 PM. |
