8 mm triple square 'socket'
I know of two places on our cars that use a triple square tool (like an Allen) - the door striker plates & the flywheel bolts (at least on the 3.2L motors).
But what size do they take? Is it 8 mm or 10 mm? I'm asking because I have a chance to buy an 8mm one for a decent price used but don't want to do so unless I need it for the car. Thanks.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
Friend of Warren
I can't remember either. I think it is 10mm. Either way, Sears sells them.
Kurt V No more Porsches, but a revolving number of motorcycles. |
The flywheel tool is 12 mm.
For what it's worth, Targa top latches employ triple-square bolts (can't recall the size). Brian |
triple square? is that what it is called? damn, i have been calling it the "12 pt, similar to a torx/ allen socket, thingy".
poof! gone |
On my car, the flywheel bolts were 12mm and the pressure plate bolts were 10mm. They both were a biatch to get off. Personally I think triple square sockets are idiotic and should be banned. What is wrong with a hex nut????
1972 911T targa |
Triple Square is stronger. Never use a Torx (or Bristol spline) both of which look similar - none of these interchange.
Thanks for the answers: 8 mm triple square - door striker plates 10 mm triple square - clutch pressure plate cap screws (some years) 12 mm triple square - flywheel cap screws (some years)
Don't forget the CV joints, although in later years, Porsche went to hex, which requires more fiddling with your torque wrench when you tighten them up.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
Senior Member
triple square - a square has 4 corners * 3 = 12 points
78 Euro 911sc Targa 03 Hayden SCWDP |
poof! gone |
The door striker plates are 8mm triple square...
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
