Neatrix springplate bushing adhesive?
I need to choose an adhesive, so I need to know what material the bushings are composed of, and what is the coating-plating on the metal surface?
thanks in advance!! richard |
When you get the bushings it will come with a super glue. IMO the glue is useless and won't hold for long anyway. I glued in my new bushings, drove the car to settle in the suspension and then had to re-index and found the bushings had come unglued. I didn't bother trying to re-glue and just put them back in. If you search spring plate bushings, you will find this is not uncommon.
I used silicon spray, and haven't had a squeak yet.
Zoanas,
I'm sorry...did you say something...? |
Adhesive??? I used clear grease four years ago....never a squeak.
astroglide
Sorry, nothing to see here... move along. |
| All times are GMT -8. The time now is 09:57 AM. |
