not sharp's Avatar
Question Neatrix springplate bushing adhesive?
I need to choose an adhesive, so I need to know what material the bushings are composed of, and what is the coating-plating on the metal surface?
thanks in advance!!
richard
84 Carrera Cab - ROW
Thanks to this Tech forum!!!!!!!!!
Tranny rebuilt etc..
Fresh Konis,
Lowered front,,
R&R injectors,
Wonged,
Valve Adjust,
Electrical solutions,
Next;
Lower rear, Corner balance
Old 05-16-2007, 08:40 AM
When you get the bushings it will come with a super glue. IMO the glue is useless and won't hold for long anyway. I glued in my new bushings, drove the car to settle in the suspension and then had to re-index and found the bushings had come unglued. I didn't bother trying to re-glue and just put them back in. If you search spring plate bushings, you will find this is not uncommon.
Tony G
2000 Boxster S
Old 05-16-2007, 11:25 AM
UFLYICU
ZOA NOM's Avatar
Send a message via Yahoo to ZOA NOM
I used silicon spray, and haven't had a squeak yet.
_______________________
Racer Rix Spec911 #5
prc-racing.com
Old 05-16-2007, 04:27 PM
Designer King
Paulporsche's Avatar
Zoanas,
I'm sorry...did you say something...?
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 05-16-2007, 04:47 PM
Registered ConfUser
Adhesive??? I used clear grease four years ago....never a squeak.
Mike
Old 05-16-2007, 05:12 PM
astroglide
Peace, Ron
www.ronorlando.net
78SC Targa 3.2 SS, 964 cams, CIS, SSI's,Dansk
Own a gun and you can rob a bank , own a bank and you can rob the world.
Old 05-16-2007, 05:28 PM
UFLYICU
ZOA NOM's Avatar
Originally posted by Paulporsche
Zoanas,
Sorry, nothing to see here... move along.
prc-racing.com
Old 05-16-2007, 09:42 PM
