Fires in early CIS cars
What causes so many fires in this part of the early CIS cars?
Old 05-16-2007, 12:18 PM
19 years and 17k posts...
azasadny's Avatar
I think it may have something to do with the 90-100psi pressure in the fuel lines. I had a leak in mine several years ago and there was a fine spray of fuel that misted over the engine and it could very easily have been disastrous. With my Weber setup, the fuel lines are at 3.5psi, which makes me feel better. Those high pressure fuel lines are also getting older and cracking and the fittings and clamps are tired, too.
Art Zasadny
Learning the bass guitar
www.ford.com
Old 05-16-2007, 12:31 PM
Non Compos Mentis
I bought my 1973.5 at an auction after it had an engine fire. I thought it was probably 30 year old fuel lines next to a hot engine that finally had enough.
Old 05-16-2007, 01:10 PM
I have 73E with cis and have to replace the fuel lines almost every year because they bleed gas throught the casing I always have extra fuel line with me but find it very fustrating.Im never sure when there going to leak. No fire yet.
Tom
Old 05-16-2007, 01:26 PM
#29 SCWDP (muhaahhh!!)
Gene Wilkes's Avatar
Excellent reason to carry a Fire Extinguisher!!
IslandmanFL
SOLD...78 911SC (ROW) cabriolet/widebody
hear BEBE purr!!
92 325is
Now living in Sunny West Palm Beach FL!
Old 05-16-2007, 01:42 PM
Slumlord
Porsche_monkey's Avatar
I think by the time you discover the fire, stop, get the extinguisher out, and pop the tail up, it is too late.
You need the halon piped system. Pull a pin and the fire is out.
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 05-16-2007, 01:45 PM
It's not difficult to set up!
IslandmanFL
hear BEBE purr!!
92 325is
I agree with PBH....
By the time you grab the extinguisher, pop open the hood, which could cause a flash and an extreme danger to you, its pretty much on its way out!!! My recommendation........................KEEP YOU COMPREHENSIVE INSURANCE UP!!!!!!
Bob
Old 05-16-2007, 01:54 PM
One of the other reasons is that they don't have fuses in the fuel pump electrical circuit. Last summer my car had the fuel pump short out and in doing so it melted the wiring back into the main harness. The insulation completely melted off of the wires leaving hot, bare copper wires that were still live (they get their power direct from the battery). If the pump had been leaking, it would have been all over. When I replaced everything, I put in a fuse. If you have a 73.5 CIS car you might want to do this as a preemptive measure.
Joe
1973 911 RS replica, Irish Green
1972 BMW 2002
1968 BMW 1600
1965 Triumph TR4A
1961 Land Rover Series 2 88
Old 05-16-2007, 02:24 PM
I think a reason is that a bad mechanic installed the motor and caught the fuel line on the tranny causing it to rub. I have seen this on 2 SC's so far.
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 05-16-2007, 02:32 PM
If i ever use my 9 lb. halon, I'll just shoot it thru the grill! Won't waste time trying to open it! I'm seriously thinking about running lines into the engine compartment so I would only have to hit the trigger!
IslandmanFL
hear BEBE purr!!
92 325is
Old 05-16-2007, 02:38 PM
Designer King
Paulporsche's Avatar
Brittle old plastic fuel lines under pressure +1
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 05-16-2007, 04:50 PM
