power to coil....no spark???
I am almost finished with the 2.7-3.2 install and I have power to the coil but nothing leaving the coil. Anyone have any ideas on what I should try next? I have fuel, but no spark.
Thanks!
Old 05-17-2007, 07:00 PM
Hi Kelly,
There should be a green wire connected to the #1 terminal. Nothing else.
This green wire goes back to the DME Control unit, pin 1. The DME makes and breaks the green wire circuit to ground.
If you connect a test wire to pin 1 of the coil, with 12 volts on pin 15 of the coil, then alternately touch the test wire to ground, you will get a spark from the coil if it's good.
Make sure the DME is getting signals from the speed and reference sensor.
You really need a schematic to trace all the wires. Bentley is a good source.
DOUG
'76 911S 2.7, webers, solex cams, JE pistons, '74 exhaust, 23 & 28 torsion bars, 930 calipers & rotors, Hoosiers on 8's & 9's.
'85 911 Carrera, stock, just painted, Orient Red
Old 05-17-2007, 08:10 PM
PRO Motorsports
Tyson Schmidt's Avatar
I posted a reply thinking it was still a 2.7, then realized my mistake and deleted it.
In addition to what 2.7racer posted, just check that the speed and reference sensor connectors aren't transposed.
Also check that the DME has a good ground, and the connector at the DME is fully seated.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 05-17-2007, 08:41 PM
