Born to Lose, Live to Win
ramonesfreak's Avatar
Speedo question
Hi..after failing at trying to replace the odometer gear in my 83, VDO speedo...i drove it today and learned that the needle shows approx 18 MPH slow....and when I come to a stop, the needle stops at what appears to be way too low...below where I would guess Zero is. photo below...
question...did I permanently damage the needle, or is there a way i can adjust the needle....or should I just have a pro fix this when I send it in for the odometer fix?
note* when i attempted to fix the odometer, the needle got pressed up against the face tightly for a few minutes.
does your needle stop where mine stops when your not moving?
Thanks.
Things fall apart; the center cannot hold…
1983 911sc
2025 Chevy Colorado ZR2
Old 05-17-2007, 06:58 PM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
seems like your needle has moved on its shaft. I would have a professional deal with this. North Hollywood Speedometer seems to be doing good work..... Good luck
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 05-17-2007, 07:30 PM
Thanks. I suspected it moved.. guess I was wondering if I could simply move it back...Most likely ill send it off. i just hate to be with out the speedo for so long.
Thanks again. this forum is an incredible source of information. Thank god Al Gore invented the internet :-)
1983 911sc
Old 05-17-2007, 07:39 PM
