Too loud, too old?
Just installed a complete B&B stainless exhaust system with HE's I purchased from a fellow pelicanite. Car has a mildly warmed over early 3.6 motor(chip, cams, head work, air filter, Lt flywheel) and runs well. It sounds great except between approx 1800 to 2300 RPMs. It has a drone that radiates throughout the car and is very loud and in time will annoying. The idle is deep and almost mellow. Once above 2300 and at cruising speeds on freeway it is almost quite. The system is the long tube header design with the 2 in 2 out muffler. This is a DD and would like some advise on other alternative mufflers , mods, or would resonators tips effect the sound level? Anyone else have this or a similar system and have had the same problem?
84 911 Euro
3.6 liter
Old 01-23-2007, 07:13 PM
dan79brooklyn's Avatar
I have a B&B with dual exhaust outlet. It has a drone as well. Doesn't bother me much anymore...Sorry I can't offer any more help. I think I have also developed an instinct for not driving in that RPM range.
Current Drivers - 2006 BMW 1 Series & MB E320 Wagon
(new addition 1998 Mazda Roadster)
EX - 1993 Porsche 911 Carrera 2
EX - 1979 Porsche 911SC TARGA
EX - 1976 BMW 2002
Old 01-23-2007, 07:22 PM
drag racing the short bus
dd74's Avatar
I believe all 2/2 mufflers have some sort of drone. I had a Triad, and it droned. I simply got used to it. The only real way to get around the drone, I believe, is to go to a two-in-one-out muffler.
The Terror of Tiny Town
Old 01-23-2007, 07:26 PM
efhughes3's Avatar
Fabricate a cap for one side. It WILL take the resonance away. I made one for my Fabspeed 2 out on B&B headers, and I've got a drone from 2600-2800 RPM, and it cures it. Two small bolts, and it's off. I did a dyno run with the cap on before running with it off, and it did make the engine suffer by 7 HP.
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 01-23-2007, 07:27 PM
my m&k 2 in 2 out drones at the same rpm's as well
Old 01-23-2007, 07:55 PM
Thanks guys, I guess I'm not alone with this problem. I will try the block off method and see what happens. Included in the sale but not installed are two tips that are capped on the ends and have a large slot on the bottom for the exhaust to exit. Anyone have or using these? What are the results?
84 911 Euro
3.6 liter
Old 01-24-2007, 03:53 AM
Don't spend any time between 1800 and 2300 rpm?!
Old 01-24-2007, 05:09 AM
efhughes3's Avatar
Don't know what those are. I welded two tabs iwith drilled/tapped holes nside the RH pipe, and made a cover to shape that slips in the pipe and sits on the tabs. Two bolts later, I'm capped-no resonance, and a bit quieter. Great for when I take the wife somewhere or on a long drive.
Ed Hughes
2015 981 Cayman GTS
Old 01-24-2007, 05:26 AM
randywebb's Avatar
somebody should make these things in a few different diameters...
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 01-24-2007, 11:45 AM
efhughes3's Avatar
Randy, were you going to include something in your post?
Ed Hughes
2015 981 Cayman GTS
Old 01-24-2007, 12:04 PM
randywebb's Avatar
not sure what you mean - I can't make them
Old 01-24-2007, 12:24 PM
efhughes3's Avatar
Oh, I thought you were going to suggest another fix, didn't realize you were talking about caps previously discussed. I'm a little slow sometimes.
Ed Hughes
2015 981 Cayman GTS
Old 01-24-2007, 12:32 PM
Mike,
Glad you got the system on and running. The two blanked off pipes are the "limerock tips" - basically the exhaust flow is blanked off and forced to the ground to meet limerock's strict db limits. I got the system on and had the same issue, the advice I got was to put on the smaller more restrictive tips (which I did) or to blank one side off. Pretty much all 2-outs have the issue. I know some guys have gone even further with the tips - I think I have 2.75 inch outlets on, while some have gone down to 2.5 or 2.25 inches. Jack Olsen had a photo of his setup with two pipes that he had locally made, which brought it from the 3.5 inch (I think) down to 2.25 (I also think).
Post some pics, both so people can see the ride (It's a NAAAIIIICE) and to illustrate the limerock muffler tips. I had actually drawn them out (before I got a digital camera) but the search is broken.
89 Carrera 3.4
"There is a right way to go around a corner - it's called the line." -- PCA DE speaker
bryteside.com - good things happen.
Old 01-24-2007, 01:06 PM
dd74's Avatar
Is it generally true that the larger the outlets are on an exhaust system, the more noise it yields, yet at the same time, if the outlets are larger, it allows better breathing and more top end?
Old 01-24-2007, 01:37 PM
efhughes3's Avatar
That would seem logical to me.
Ed Hughes
2015 981 Cayman GTS
Old 01-24-2007, 01:52 PM
randywebb's Avatar
too wide, too long, too short -- all can interfere the wave resonance effects that make modern exhaust systems work well
it's like anti-freeze -- more is not always better (aka: optimization takes place at an interior maximum on the response surface)
aka: "Goldilocks Principle"
Old 01-24-2007, 03:09 PM
Thanks again Jared, got the system installed the day before I left to the airport to go to Daytona( Two days ago). Took it around the block and then to the airport parking lot. I will try the "Lime rock Tips" and post pics and results when I get back.
84 911 Euro
3.6 liter
Old 01-24-2007, 05:25 PM
Slippery Slope Victim
NY65912's Avatar
After reading this thread I was surprised that the general consensus is that all systems that are 2 in 2 out drone. Not to be a contrarian but I really don't feel that I have any drone with my Monty 2 out being fed with SSIs.
I guess I'll just have to take it out for a "test" drive and listen closely.
Truth be told I'm usually not in that rpm range and I'm enjoying the music of the carbs and exhaust.
MikeČ
1985 M491
Old 01-24-2007, 05:50 PM
randywebb's Avatar
mine does & it's SSI's into a Monty 2 in/2 out (3.2L carbed motor)
but it is very small and limited in the rpm range too
Old 01-24-2007, 09:21 PM
Early_S_Man's Avatar
Porsche Crest
Anybody ever try adding a slip-on & clamped extenesion to one side ... say, 2 - 3 inches, to see if that makes the drone go away or changes the characteristics??? If it did alter the drone ... you could try trimming it down, say 0.5" at a time to see where the drone was essentially gone or less bothersome?
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 01-24-2007, 09:48 PM
