911 missfire problem
Could anybody give any input as to what could be causing a missfire on my 1979 sc. I took it out on the road yesterday and she was fine,so got her out of the garage today and washed and waxed the bodywork and now when I try to accelerate she runs really rough. When i was using the hose I was careful not to get too much water in the engine area. Any ideas where I should start to look for the problem.Many Thanks
Old 08-06-2007, 12:59 PM
Driving member
jester911's Avatar
You may have a crack in your distributor cap. If so it doesn't take much water to make it misfire.
Jerry
'86 coupe gone but not forgotten
Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason.
Old 08-06-2007, 01:11 PM
If nothing happened except the washing, I would agree with Jerry. You could even have a "leak" in one of the high tension cables or connectors that will misfire with very little encouragement. Dry all electric parts thououghly and try again.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 08-06-2007, 01:27 PM
Driving member
jester911's Avatar
If you really want to get down to it let the car idle with the deck lid open. Preferably in the dark
take a spray bottle of water and give it a shot towards the dist. cap and wires.
If you have a light show then you have found your leak.
Jerry
Old 08-06-2007, 01:59 PM
thanks guys, I have only had the car 2 years and only run it in summer,so I may go and change the cap, rotor,plugs and HT leads. Thanks Again
Old 08-06-2007, 02:08 PM
Early_S_Man's Avatar
Porsche Crest
Please read the following thread all the way through, then check the green coax signal cable from the distributor on your engine:
coil to buy question
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 08-07-2007, 11:56 AM
Thanks man ,I will look into the green wire more closely.
Old 08-07-2007, 05:18 PM
It appears that a small amount of water is causing your ignition wires to short out too easily meaning your ignition wires may need to be replaced.
Cheers,
Joe
Old 08-08-2007, 02:18 PM
