-   -   SC distributor Questions (http://forums.pelicanparts.com/porsche-911-technical-forum/347986-sc-distributor-questions.html)
Mike D. 05-22-2007 03:49 PM
Is the SC distributor a magnetic pick up in it's stock form? I'm just used to seeing points and a condenser. What am I looking at here?
BTW no dizzy diagram in the 911 dia. section...
http://forums.pelicanparts.com/uploa...1179874161.jpg
Nostril Cheese 05-22-2007 03:51 PM
yep. Looks normal to me.
I think 74 was the last year for points based ignition
Mike D. 05-22-2007 04:24 PM
OK so I'm trying to hook up a MSD 6AL - in a 914 - and I have the green wire with two spade connectors - now I need to get the mag pickup adapter for the msd........
fred cook 05-22-2007 07:33 PM
MSD Connections........
Try this:
CDI Plug MSD Wires
1 System Ground Black coil wire
2 Tachometer Signal Black wire from left end of MSD unit (Tach connection)
3 Signal Ground (Green wire shield) Grd. Purple wire
4 Coil Hot +12 volts Orange coil wire
5 Switched +12 volts Small red wire
6 Signal (Green wire center conductor) Pos. Green wire
Heavy red wire +12 volts (wire to starter terminal
Heavy black wire Grd. (wire to chassis and engine)
(Looking at top of plug on wiring harness with the beveled
edges to the front.)
4 5 6
1 2 3
