-   -   Install of PC680MJ (http://forums.pelicanparts.com/porsche-911-technical-forum/348081-install-pc680mj.html)
gulf911 05-23-2007 08:29 AM
Install of PC680MJ
I purchased the battery and I am looking for a solution to either mount it in the battery box (preferrable) or to the right of the GAs tank. I own a RS look 1973T.
Thanks a lot,
Dan
Dave Nordhoff 05-23-2007 09:54 AM
http://forums.pelicanparts.com/uploa...1179939209.jpg
Here is mine mounted in stock location in my SC.
Dave
gulf911 05-23-2007 10:16 AM
Thanks Dave!
So I can safely drill though the bottom to attach the bottom plate? It looks like the hold down is riveted? How do you remove the battery?
Thanks again,
Dan
Dave Nordhoff 05-23-2007 12:39 PM
Dan,
I machined a .25" thick aluminum plate with a recess for the battery. The strap is held with screws and I used 1 bolt to the factory threaded hole. I am really happy with this battery. I do disconnect it when I'm not driving it for a few days so the clock will not drain it. Mabe I should get rid of the clock.
Dave
SoCal70RSR 05-23-2007 01:35 PM
Dan,
Rennline carries a kit for these batteries in case you're interested. Here is how I installed mine.
http://www.readynet.com/porsche/IMG_8430.JPG
http://www.readynet.com/porsche/IMG_8447.JPG
gulf911 05-25-2007 08:26 AM
Thanks Fernando, although thats a nice mount I didn't want to spend way more on a mount than the battery itself.. ;)
Thanks to all for your help!
Dan
