gulf911's Avatar
Install of PC680MJ
I purchased the battery and I am looking for a solution to either mount it in the battery box (preferrable) or to the right of the GAs tank. I own a RS look 1973T.
Thanks a lot,
Dan
Old 05-23-2007, 08:29 AM
Dave Nordhoff's Avatar
Here is mine mounted in stock location in my SC.
Dave
Old 05-23-2007, 09:54 AM
gulf911's Avatar
Thanks Dave!
So I can safely drill though the bottom to attach the bottom plate? It looks like the hold down is riveted? How do you remove the battery?
Thanks again,
Dan
Old 05-23-2007, 10:16 AM
Dan,
I machined a .25" thick aluminum plate with a recess for the battery. The strap is held with screws and I used 1 bolt to the factory threaded hole. I am really happy with this battery. I do disconnect it when I'm not driving it for a few days so the clock will not drain it. Mabe I should get rid of the clock.
Dave
Old 05-23-2007, 12:39 PM
Dan,
Rennline carries a kit for these batteries in case you're interested. Here is how I installed mine.
Old 05-23-2007, 01:35 PM
gulf911's Avatar
Thanks Fernando, although thats a nice mount I didn't want to spend way more on a mount than the battery itself..
Thanks to all for your help!
Dan
Old 05-25-2007, 08:26 AM
