dweymer's Avatar
Cool Body & Paint started
Finally started body and paint:
Donnie
Currently Porsche-less.....
Old 05-07-2007, 06:13 AM
dweymer's Avatar
The car has been at least three different colors:
Gold-original then
Ruby Red then
Silver
Reprays were very light coats
Donnie
Old 05-07-2007, 06:16 AM
"farking Porsche hero"
Rich Lambert's Avatar
What's the new color going to be?
Rich
'66 911 #303872
'07 Cayman
'17 Macan
'58 Land Rover S2 88"
Old 05-07-2007, 07:24 AM
dweymer's Avatar
A light silver, not an OEM color. Should be done some time this week, will post pics as I go.
Donnie
Old 05-07-2007, 07:50 AM
Zeke's Avatar
Are you going to use some stripper and get what little is left there?
Old 05-07-2007, 07:59 AM
abit off center
cgarr's Avatar
Whats with the deck lid? What goes there?
______________________
Craig
G2Performance
Old 05-07-2007, 08:05 AM
dweymer's Avatar
Milt- I am sanding down to good paint, or metal in most cases it seems so far. Stripper is too messy, and this is thin enough to just D/A. pretty quick. Since your here, what have you used to block? The doors are the only flat panel? I have a adjustable flexible and was going to use that.
Deck lid has been cut for my wing, I wanted to leave the support for the latch intact.
Donnie
Old 05-07-2007, 08:34 AM
Zeke's Avatar
https://www.autobodytoolmart.com/p-11685-14387.aspx
https://www.autobodytoolmart.com/p-12474-15476.aspx
Old 05-07-2007, 09:08 AM
Black and Blue
Kemo's Avatar
Send a message via Yahoo to Kemo
subscribed...
Kemo
1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore
1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver
Old 05-07-2007, 10:33 AM
Dweymer,
FWIW a long block with adhesive backed paper works best. The short 3mm block (4x6) is good for the curves. Wet sanding with 500 was good for my finish but I wish I would have done a little more wet sanding with the 500, I spent a day wet sanding by hand but wish I would have spent longer, I can still see small scratches in places through the clear coat. I hope that after I sand and buff the clear coat in places they will be harder to spot. Really you can hardly notice them and then only in certain light at specific angles.
Also if you plan on using more than one coat then, plastic can be a bad thing, the paint flakes off it really bad, (you can see the flakes that came off my car on the picture below from the plastic) use paper as the paint will stick to it better in between coats.
Guess I should have read Milts post first....the items referred to are the same as I was suggesting.
Good luck
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 05-07-2007, 11:09 PM
dweymer's Avatar
Tool/Supply update:
So far I have used:
36 grit-longboard
80 grit-D/A
120 grit-both
220-longboard
320-longboard
~1 gallon of primer
~2.5 quarts of sealer
3M lightweight body filler
3M Piranna putty-cool flowable filler
1 roll 3/4" tape
some 3" tape
Paper
15" adjustable sander
9" adjustable sander
15" longboard
Donnie
Old 05-09-2007, 02:49 PM
dweymer's Avatar
Primed:
Donnie
Old 05-09-2007, 02:52 PM
dweymer's Avatar
Sealer-you can see a few "tiger stripes" where my compressor kicked in and I did not adjust the gun.
Donnie
Old 05-09-2007, 02:55 PM
Donnie, looks good. Now get out there and block, block, block (to quote Knute Rockne).
Tell us more about what paint system or systems you're using for the sealer, primer, color and clear (if you're doing base/clear).
Brian
Old 05-10-2007, 06:07 AM
dweymer's Avatar
I am using House of Kolor products for the entire car. I'll list product, color and qty when I'm done.
Donnie
Old 05-10-2007, 07:02 AM
Thanks, it's handy for those of us contemplating diving into a new project to know the system used and other details (including likes and dislikes).
Brian
Old 05-10-2007, 07:14 AM
Tired Member
DaddyGlenn's Avatar
Subscribed
Glenn
Daily Driver - '78 911SC RoW
Endurance Racer - '85.1 944
Street/Track Project - '86 951
Race Project - 944 Spec
Old 05-10-2007, 07:51 AM
Congrats Donnie, I look forward to seeing all your hard work come to fruition!
Michael
Sans Porsche...for now
2009 Mazdaspeed 3 Grand Touring daily driver / DS autocross toy
2010 Subaru Forester X Limited - wife's daily driver
Old 05-10-2007, 08:16 AM
dweymer's Avatar
Funny how many small defects you see when put in the sun!
One last time before final sealer.
Donnie
Old 05-10-2007, 01:34 PM
lateapex911's Avatar
Donnie, you mentioned issues with your compressor. if you don't have one, I hghly suggest getting a regulator/water seperaator and putting that inline. You should have a tightly controlled supply of air and it has to be dry.
(If you are going HVLP, then ignore that , LOL()
Jake Gulick, Black Rock, CT.
'73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B]
Old 05-10-2007, 03:57 PM
