Limited Slip
Hey guys. i have a chance to buy a limited slip for my 88 911. would it matter if the limited slip came out of a C2/C4 or a 993? and if so, could i do anything to make it work? thanks for your help guys.
Sports Purpose 911 Driver
I dont' think it would but you'd want to ask this question on the rennlist 964 forum as well as search past threads here.
James Shira R Gruppe # 271 1972 911 Coupe 3.8 RS ‘nbr two’ 1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie' 1955 356 Pre A Coupe ‘old red’ 1956 356A Emory speedster build in progress |
Some of the 993 LSDs don't have the three holes for the 5-speed speedo sensor ring.
Schleprock
Based upon the parts diagrams the 964 C4 LSD looks to be substantially different internally than the 964 C2 LSD. So you'd want to possibly avoid those.
993 LSD friction discs are known to wear out pretty quickly so you'll want to ensure it's in good or rebuilt condition before purchasing. Watch out on pricing too. Some people seem to think these diffs worth top dollar used. For a little more than the $ some people ask, you could get a better rebuilt Porsche Motorsports diff from Geary.
Kevin L '86 Carrera "Larry" |
The 993 LSDs do indeed have the "carbon" friction discs that wear out within 5,000 miles, or a single race weekend. But proper plasma-sprayed discs can be installed that will last about 10X as long.
so the 993 and the c2 lsd will work..what if the 993 lsd doesn't have the holes for the 5-speed speedo sensor ring? is it still worth getting it and and trying to make it work if possible? thanks for the help
