LinkBack | Thread Tools | Rate Thread |
Somatic Negative Optimist
The vac advance is supposed to be above the butterfly (In front of the TB) and the retard on '80-'83 below the butterfly) Rear of TB).
Is this correct? Even at 850 RPM, there is strong suction above the butterfly on the advance line pulling the full ~5 deg in idle. Some thoughts: Porsche states to set timing at 5deg with vac disconnected for SC's. That would mean that Porsche recognized the effect of the vacuum even at idle??? More observations: I retarded the timing to a total of 29-30 max. vac connected which leaves the timing at 8-9 deg in idle with vac re-connected. (If I set it 30-32, it'll be 10-11 deg vac connected) At this point, I wonder about the total advance possible with the SC-distributors? I have 3 distributors to play with: '78, '80 and '82. They appear to perform the same. Any thoughts?
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
