-   -   3.2 distributor question if going carbs (http://forums.pelicanparts.com/porsche-911-technical-forum/349865-3-2-distributor-question-if-going-carbs.html)
rfuerst911sc 06-02-2007 11:16 AM
If you remove the EFI induction and ECU is there a way to use the stock distributor on a 3.2? If not what distributor can you use?SmileWavy
TimT 06-02-2007 01:01 PM
I have a NA 3.2 in my 914.
The distributor is a recurved SC distributor. The stock distributor doesn't have an advance mechanism built in
rfuerst911sc 06-02-2007 01:30 PM
That must be a modified dist. as the SC's run counter clockwise right? Who did the mod?
TimT 06-02-2007 02:24 PM
Yes its not a "stock" SC distributor. The name of the place that did the re-curve escapes me now..
Also the SC distributor went into my 3.2 whose case has never been split
randywebb 06-02-2007 03:17 PM
Steve W. can do that. Dunno who on E. Coast or SE.
Maybe Pdoc? - tho he's in TN.
You can always ship it for not much $$
shbop 06-02-2007 03:42 PM
Just went through this on a 3.0, and ended-up going with Electromotive/Clewett. A bit more up-front money, but great versatility and very simple install.
