another 17" tire/wheel question
I have 17" Fikse wheels with 215/45 zr 17 michelin PS on front and PO replaced rear with 255/40 zr 17 yokohama AVS100(?).
I seem to get a lot of road noise from the rear. I am looking to replace the rear tires, Michelin in 255/40/17 are very expensive. I am considering to replace the whole set as the front ones are probably also several years old. One choice I looked at are ContiExtremeContact. They rate pretty high with tirerack and don't break the bank. I have seen several size recommendations. Can I run 205/50/17 in front instead of 215/45/17? Would steering be easier? Does anybody have the noise issue with 255/40/17 on rear? The Yokohamas are rated as very noisy tires. Can I run smaller tires on the rear wheels? I appreciate any input... Oh yes, I don't track the care, just street use, would prefer all season tires...
Dietmar 1987 911 Carrera 2008 RS 60 Spyder |
The model of each brand also make the diff. You might have bad experience regarding noise with a model of Yokohama but you might not with another model. I didn't have good exp. with both Yokohama and Michelin, too bad I don't remember the model. Funny, I had good experience with Kumho, and Y and M are both more expensive then kumho.
PS: I don't race but I do get 100+ once in a while when the road is empty.
Fat butt 911, 1987 |
Run a 205/50 or prefferably a 225/45 in the front.
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
