Thanks for all the replies. Looks like I have my first project.
-Jim 75 911S targa SOLD 67 912 SOLD 1984 911 Carrera |
I wouldn't rush right out to buy that oil cooler until you drive the car and see where it's at. Chances are excellent that if it was rebuilt, all the right stuff has been done to it; i.e. timecerts, 11 blade fan, thermal reactor removal, air pump removal, air pump plugs, etc. But if not, you have other places where your money is better spent. Swapping out the 5 blade fan (there are some still out there) for the 11 blade fan would be a much better investment than the oil cooler. If all that stuff has been done already, the car may run at a good temp w/o the new oil cooler. FWIW, my 77 ran cool in Wisconsin even on track days. Lots of folks in this region actually block off their oil coolers early in the season-like July.
Good advice too. Don
72T Coupe - SOLD :-( |
Good point SLO-BOB. The shipper picked up the car today so it should be in my driveway within the next week. You guys don't realize the change I'm about to make. I have owned mustangs and shelbys for the past 15 years. Now there will be a "German" car in my driveway. I think my neighbors will freak. should be cool. I always loved these cars when I was growing up.
RETIRED
If you ARE NOT running a thermostat on an air cooled engine and it NEEDS a block on a cooler during the winter, it's a ""Billy Bob" fix...... Flame away.....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
I'm not suggesting that blocking an oil cooler off is good or bad- just what I've seen. What I am saying is it would be foolish to assume one needs the above and beyond oil cooler before driving the car and assessing it's running condition. Especially considering he lives in a relatively cooler climate.Chatas 17- While tastes are subjective I'll say you are in for a treat. I've driven a number of Mustangs and while they both are sports oriented cars, they couldn't be more different. The 911 won't be as torquey fast as the stang, but it will make up for it in the handling department. Nine 11s point way better- you'll love how you can just forget about the brakes (within reason) on city street corners and just turn the wheel and the car will follow with no drama. You'll probably hate the way it shifts. Second gear is usually pretty notchy. Do a search on how to shift a 915 gearbox-it's NOTHING like your stang. Despite that, the positives make it all worth it. I'll never be w/o a 911 again. Welcome to the club! Last edited by SLO-BOB; 06-06-2007 at 08:24 AM.. |
Chatas, enjoy the new car and let us know how it runs when you get it. Don
Thanks for the welcome. I have to admit, I'm pretty excited about driving the car. It is on it's way as I type. The history on the 911 has always been in the back of my head. The targa is mainly for my wife. I am looking for a coupe if everything works out. I figure I will pick up another 2 feet in my garage with the 911 replacing the mustang! My mustang (fastback) hit the reserve on Ebay last night. I guess it's going Thanks again, Jim
Heat
I have a 74 2.7 and I have done allow to make sure I dont overheat the motor. If my motor gets to 210 its because I am pushing it hard!
1. Get the Oil cooler for the front right fender, 2. Some people use other brands but I use the LUCAS oil treatment..1 for every 4 quarts. this will lower the temps and treat your engine right. 3. Check out this thread and my post for the other necessary oil system mod, this will do great things for your pressure and foaming... Oil spewing from oil tank breather 4. Clean your motor, top and bottom....remove the alternator and clean out all the gunk and dirt from the top of the motor. All of this dirt and grease traps heat. 5. Clean your oil tank, you would be surprised how much dirt and junk surround your oil tank and keep heat in. 6. get rid of the heat reactors and go with the SSI setup for the exhaust. The cooling fan helps cool the headers and cuts down on radiant heat. 7. I got the "HEAT SHEETS" for the valve covers and they look nice, and they say they work, but I cant offer any real proof. Just take the time to invest in cooling your motor. That is the key to a healthy 2.7.... Guys would run temps 250 and higher and the studs would pull right out due to the different expansion rates of the metal combined with other little odd ball reasons. Chris
Signature Phrase " CATCH ME IF YOU CAN" 1988 Porsche 930 "Squerly" Built by "Porsche Doc" -------------------------- 1974 Porsche 911 (2003 - 2012) 2000 Boxster S (2006 - 2008) |
I have 127K miles on my un-rebuilt '76 2.7 and it has NO external oil cooler. The 5 blade fan and the thermal reactors were removed very early in its life by the original owner. It runs 180 to as much as 210 on hotter days; usually about 190. But remember I am in Southern California where it is usually warm, the traffic is bad and I don't use it as a daily....the traffic is just too consistent to make driving it every day much fun. I can hardly ever get into 3rd gear!
Anyway, I ONCE got caught in traffic and it went up to 240 biefly and I was about to pull over and shut it down before traffic eased up and I was able to get moving. The temp dropped quickly back to about 210. I agree that MOST of the 2.7's have had the TR's and 5 blade fans removed. Afterall, the newest of these engines is 30 years old! One last comment: You're used to driving Mustangs? You realize this car isn't made for the same purpose as the Mustang, right? What I'm driving at is it won't tolerate repetitive dropped clutches, etc. Just thought I'd make the comment.
Dan in Pasadena '76 911S Sahara Beige/Cork |
19 years and 17k posts...
Cleaning the engine, oil tank, oil cooler(s), lines, etc... can all help to lower temps. when I replaced my 2.7L engine last summer, I cleaned everything up while i had easy access and the temps dropped. Stuck-on grime, oil, debris, etc... can't help.
Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com |
