Corrosion Concerns
I've noticed some rust on the top of my gas tank - Weird place for corrosion to form, me thinks...Anyone else have this problem? Fixes?
Mark
'89 Linen Grey Coupe - Sold, but have visitation rights!
'13 991 Coupe - The adventure continues!
Old 06-11-2007, 10:42 PM
Gon fix it with me hammer
svandamme's Avatar
fix : rough it up with sand paper, then POR15 the bugger
Stijn Vandamme
BIMDIESELBMW116D2019
Old 06-12-2007, 01:37 AM
S2GART's Avatar
if it is indeed rust, I second the motion to use POR15. POR 15's only weekness is sun light, but on your tank, that won't be an issue.
The "collection"
1983 911 SC Targa (1 of 1430 imported)
1994 MB E320 Coupe (1 of 825 imported)
1992 MB 190E 2.6
2004 Volvo V70 2.5 Turbo (1 of a bazillion imported)
Old 06-12-2007, 03:15 AM
pozee's Avatar
MarcoB - Make sure that's not rusting from the inside out. Seems like it may be. If that's the case, addressing the rust from the outside will not help you. Condensation in the tank may be the cause.
If it is rusting from the inside out, you will need a professional repair or preferably a new tank.
Hope it's just on the outside.
pozee
Old 06-12-2007, 04:45 AM
85eurocarrera's Avatar
My guess is that is not rust, but hard to tell from pic. If it is rust then you will have to clean up that area and see how bad it is. Looks like something spilled or leaked.
Joe
Old 06-12-2007, 06:17 AM
Slumlord
Porsche_monkey's Avatar
If it is rusting from the inside out you'll know right away, it will break through into the tank. Start scraping. And order POR and Metal Ready.
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 06-12-2007, 06:19 AM
Thanks, guys...Hadn't even thought it may be an "inside out" issue! I'll get the Gerber guys to give it a look.
Mark
Old 06-13-2007, 07:07 PM
