cak cak is offline
ham antenna ideas?
Probably seems like a strange idea to many, but I'd like to mount a 2m/70cm antenna on my 911. I'm looking for suggestions from those who have tried...
The "obvious" thing is to drill the Targa bar for an NMO mount, but I'm not going to do that I'm thinking more of a trunk lid lip mount, probably on the engine decklid. Not a great location for efficiency. This is primarily for APRS, so that's OK with me.
73 de chris K6DBG
Chris Kantarjiev
73.5 911T Targa
and the rest: 66 TR4A 69 FJ40 70 GT6+ 00 2.5RS
Old 02-07-2007, 11:22 AM
david914's Avatar
Don't they make a 2m glass mount antenna (a la cell phone)? That would be the least invasive to your car. You could mount it in the middle of the Targa glass right behind the Targa bar.
David Dryden
'86 911 Coupe
'05 BMW X5 4.4i
Old 02-07-2007, 11:45 AM
cak cak is offline
Yes, and I'm considering that. It means a fairly long cable run under the targa bar trim (lots of interior disassembly). I'm kind of hoping to avoid that ... though I guess getting to the engine compartment isn't much better!
Chris Kantarjiev
73.5 911T Targa
Old 02-07-2007, 11:54 AM
Sultan of Sawzall
rouxroux's Avatar
I've had great results with the "through-glass" cell phone-type antenna sold by Antenna Specialists. Before that, I was using a Larsen "Long Ranger 5/8 wave duck" on a clip-on window mount going to a HT. 73
Gruppe B #319
'66 Monza coupe 110/PG(white)
'95 993 cabriolet (wife's)
Old 02-07-2007, 12:05 PM
Banned but not out, yet..
RSBob's Avatar
If those suggestions don't work for you, my first targa had an aentenna mounted to one side of a U-shaped plate (painted black) . The other side of the plate was then mounted by bolts through the engine grill. No part of the car was drilled or altered. Sorry, no pic of it.
Old 02-07-2007, 12:23 PM
WHCJr72S's Avatar
I am assuming that this is for your 1973. There are two bolts that hold the rear bumper on. They are located on the top part of the bumper and you could make a flat plate that bolts to them and mount the antena to it.
Bill Cilker, Jr.
911S Registery #98, R Gruppe #272
1972 911S
1931 Model A Ford
Old 02-07-2007, 12:36 PM
cak cak is offline
Yup, but it's really better to mount higher than lower (for 2m, the antenna will be between 19 and 38 inches in length).
I'll spend a little time investigating how the targa bar interior is mounted.
Thanks for all the ideas!
Chris Kantarjiev
73.5 911T Targa
Old 02-07-2007, 12:40 PM
This has a CB antenna mounted on the lid. It's a temp 1/4 plywood bolted with long screws w/a piece of rubber separating the wood from the grill.
The antenna length is not long as I can enter a garage without scraping. Short length hinders effectiveness. I also have a longer one that I'll be using as I'm riding w/another pelicanhead soon and distance will become important. There is a ratio of antenna length that should extend above the roof line if it's base is below the roof. There is also db selection. There is also different antenna designs. such as straight rod vs wrapped wire around rod etc.
i know nothing about ham antennas... have fun
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 02-07-2007, 05:31 PM
i couldn't add another pic to above.
hope this matters
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 02-07-2007, 05:35 PM
cak cak is offline
I finally got a Larsen "Kulglass" through-glass dual-band antenna and mounted it at the base of the rear window (it's rather tall). Easy install, works OK, SWR is a little high but acceptable - that seems to be the nature of the beast.
A couple of days later I wanted to install replacement throttle springs and discovered that the coupling transformer housing interferes with the engine decklid! I can open it enough to work, but not to engage the lift cylinders. I'll get a remount kit and try it a little higher, but I may be back in the market.
RoninLB, how did you route the cable into the passenger compartment?
Chris Kantarjiev
73.5 911T Targa
Old 03-20-2007, 09:47 AM
from engine compartment down into tunnel area into the cabin.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 03-20-2007, 11:37 AM
cak cak is offline
OK. I was sort of afraid of that. Is there a good way to exit the tunnel? I haven't really poked around that area much at all yet.
Chris Kantarjiev
73.5 911T Targa
Old 03-20-2007, 11:47 AM
i entered through the transmission's nose area outer section of the rubber boot as it enters the shift coupler area. Inside the shift coupler area i cut a hole in the cover and ran it next to passenger seat.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 03-20-2007, 11:54 AM
defcon65's Avatar
I had a college buddy who made a 2m 'trap antenna' and mounted it to his Ghia for mobile DXing. I'll look for the picture when I get home - it was a god-awful looking assembly of wire coils, PVC pipe, aluminum tubing, coax cable and exhaust clamps. Laugh if you will, this guy was a ham radio savant and EE major, he used to talk to guys 500 miles away on about two watts output.
Joe
85 Carrera
64 Honda Dream - for sale
71 Hodaka Super Rat - keeper
Old 03-20-2007, 12:26 PM
Sultan of Sawzall
rouxroux's Avatar
defcon55, are you sure it was 2m and not QRP 10m or 20m? 200 miles is not that big of a deal if you live in an area served by repeaters with any height, If you have some pics, I'd love to see em. (Now if he was DX'ing 2m on 146.52 simplex at 200 mi., I'd be really impressed)!
...I used to operate "Field Day" 10m CW mobile in a Vega back in the 70's. I'd drive to the top of Monte Sano mountain in Huntsville, Al, park at one of the overlooks. Had a knee-mounted "flight board" with a vibroplex bug on it and a 10m trap vertical on the middle of the back bumper, complete with a fishing line guy wire to the top of the hatchback. Looked strange, but quite a bit of multiplier points! (People used to laugh when they'd get a QRP DX CW QSL!!!)
Gruppe B #319
Old 03-20-2007, 02:45 PM
cak cak is offline
They may laugh ... but that's all I do! Working on QRP CW DXCC (from home, not mobile)...
73 de chris K6DBG
Chris Kantarjiev
73.5 911T Targa
Old 03-20-2007, 04:33 PM
Sultan of Sawzall
rouxroux's Avatar
I forgot to add QRP DX CW / MOBILE...that's what I meant. WAS was fun QRP, thank God I did it during sunspot cycle 22...that was years ago. hi
Gruppe B #319
Old 03-20-2007, 05:11 PM
cak cak is offline
Ah. Yes, adding /M to that makes it a lot more interesting.
I did QRP WAS over the past year or so. A good challenge
here at the bottom of the cycle! I *think* there are enough DX entities in the western hemisphere that I can get DXCC. Will be tough, but fun.
Back to pcars...
Chris Kantarjiev
73.5 911T Targa
Old 03-20-2007, 06:35 PM
defcon65's Avatar
If my memory serves me correctly (this was in 1989) it was a two meter handheld with two watts output, those details seem to stick in my mind. The trap antenna was about six to eight feet tall and made out of 1" aluminum tubing with the traps constructed of copper wire wound around short sections of 1-1/2" PVC tubing placed at intervals up the pipe, which was bolted to a piece of wood that he clamped to the front bumper. It was the freakiest looking thing I ever saw. He used my shop to build it and I remember that the length of the coil wires and spacing of the traps was a critical adjustment that required his trusty 100 pound mil surplus oscilloscope.
It was a running joke with my roommates at the time, having 'marconi' back there twiddling on his antenna every night. I was amazed when he demonstrated the completed rig, talking to other hams on the east coast from a parking lot in Iowa City with two watts power!
He got this design from an old issue of '73' magazine - one in his collection of about 500 radio mags. He was a unique individual, for sure - his intellect was about one inch wide and ten miles deep - all electronics and radios. Last I heard he was working for a defense contractor in Connecticut on submarine communication systems.
Joe
85 Carrera
Old 03-21-2007, 08:09 AM
Grady Clay's Avatar
Chris,
There should be four little threaded inserts in the Targa bar for mounting a ski rack. They are well grounded as they are in the Targa bar sub-structure, not the SS cover. As I recall they have plastic plugs in them and are partially under the rear top/side window seal.
You can make a nice bracket to mount the antenna. You might make sure the SS cover has a good RF ground.
I would think the best route for the cable might be at the upper-rear of the door window.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 03-21-2007, 09:27 AM
