Flywheel Warped?
Last year I had my flywheel resurfaced.
I just hooked up my dial indicator to the flywheel - the flywheel is attached to the crank and I find that there is about .06mm variance throughout one revolution. Would this be considered warped? -Rob
'79 SC |
Slumlord
That is 0.002", so I would say it is fine.
84 Cab - sold! 89 Cab - not quite done 90C4 - winter beater |
Less brakes, more gas!
Recent relevant thread:
When to resurface a flywheel?? Enjoy, Michael PS there is a runout spec. My 82,83 spec book lists .1mm. This assumes your crank is also spinning straight. Probably not a bad assumption.
Michael ![]() '82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah '13 Cayenne GTS Last edited by euro911sc; 06-21-2007 at 08:14 PM.. |
