sbmackie's Avatar
Wheel/tire size?
If I go to a 15 inch wheel for the track, will that be the equivalent of going to a lower gearing?
Also, is it total wheel/tire diameter that affects this? In other words, if I went to a lower profile 16 inch tire that gave the same total diameter as a 15 inch wheel with a higher profile tire, would it be the same "gearing" effect?
Scott
Old 06-21-2007, 08:47 PM
Non Compos Mentis
Re: Wheel/tire size?
Yup. Overall diameter is what counts.
Old 06-21-2007, 09:28 PM
Bill Verburg's Avatar
Actually what really counts is the loaded rolling radius of the tire. A tire on the road is no longer circular. Most manufacturers provide this info
the revs per mile is almost as good, but slightly less useful
Bill Verburg
Old 06-22-2007, 05:32 AM
