-   -   AAR wiring info needed (http://forums.pelicanparts.com/porsche-911-technical-forum/353296-aar-wiring-info-needed.html)
paslantnose 06-21-2007 04:32 PM
Can anyone tell me the correct wiring for the AAR?
Mine has had the wires cut and removed from the engine harness.
Where do i need to connect it to in order for it to work again?
By looking at the wiring diagrams, i see that it used to draw power from a red w/white wire off of the fuel pump relay.
Ok, no big deal to connect that back.
Does this mean that whenever the fuel pump is running, the AAR has power?
If that is correct, i guess i've solved it myself BUT, i just want to be sure about this.
equality72521 06-21-2007 05:50 PM
You are correct.
cmonref 06-22-2007 03:10 AM
The AAR and the WUR are powered on the same circuit. Have the WUR wires been cut also?
