| Registered |
				AAR wiring info needed
			Can anyone tell me the correct wiring for the AAR? Mine has had the wires cut and removed from the engine harness. Where do i need to connect it to in order for it to work again? By looking at the wiring diagrams, i see that it used to draw power from a red w/white wire off of the fuel pump relay. Ok, no big deal to connect that back. Does this mean that whenever the fuel pump is running, the AAR has power? If that is correct, i guess i've solved it myself BUT, i just want to be sure about this. Last edited by paslantnose; 06-21-2007 at 04:49 PM.. | ||
|  06-21-2007, 04:32 PM |
| sudo apt-get purge 930 Join Date: Jul 2006 Location: Brandon, FL
			You are correct.
				__________________ Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey | ||
|  06-21-2007, 05:50 PM |
| Registered Join Date: Dec 1999 Location: Richmond, VA  USA
			The AAR and the WUR are powered on the same circuit.  Have the WUR wires been cut also?
|  06-22-2007, 03:10 AM |
